New Engine Harness/fan hookup ? - Chevelle Tech
post #1 of 12 (permalink) Old Dec 23rd, 12, 8:00 PM Thread Starter
Gregg
This is a 70 Chevelle BB with AC.
Replaced the original engine harness with a new American Auto Wire Harness.The new harness has an orange wire with boot for the blower motor. The original harness had this wire cut off.
Previously with the original harness everything worked, fan on all speeds AC and heater and vent.
Does anyone have info on where the orange wire connects? I'm thinking to the blower motor, but before I take the inner wheel well out I thought to ask you all first.
The one problem I have in addition to this is that the black wire from the horn relay is not connected, I need a new one cause someones big fat foot cracked the fuse link shell and I have no electric going to the relay for testing. BTW it was my fat foot! Sure would have liked to put blame elsewhere, but I cant.
Gregg
69 Malibu SS drive train
70 SS Chevelle LS5
gzwhite is offline
post #2 of 12 (permalink) Old Dec 23rd, 12, 8:10 PM
Levon
Re: New Engine Harness/fan hookup ?
With A/C you do not use the single orange wire.
A/C has it's own harness and power to the fan comes from a purple wire off of a relay and the resistor farm mounted on top of the A/C box You should have a big orange wire with an in line fuse that is connected to a plug shared with a black wire The black runs over to the horn relay.
Time for a wiring diagram ;-). www.classiccarwiring.com has a good colour one (although we have found 1 error in it but it will not affect what you are doing).
Levon Hovagimian
Team Chevelle #279
1966 427 Corvette SOLD
Priddis Greens, Ab. Canada
LevonH is offline
post #3 of 12 (permalink) Old Dec 23rd, 12, 10:50 PM
Donny
Levon, The orange wire was either cut off where it broke out from the harness or was looped about every 6 inches, than taped back to the trunk of the harness depending of which plant the car was built at. The purple wire in the A/C harness is the blower wire that gets used. The 1st three speeds should work fine without that black wire hooked up to the blower relay. That only comes into play on "high" speed.
Donny
aawtech is offline
post #4 of 12 (permalink) Old Dec 23rd, 12, 11:24 PM
Levon
Hi Donny. Merry Christmas.
Levon Hovagimian
Team Chevelle #279
LevonH is offline
post #5 of 12 (permalink) Old Dec 23rd, 12, 11:27 PM
Donny
You too buddy!
Donny
aawtech is offline
post #6 of 12 (permalink) Old Dec 24th, 12, 5:45 AM Thread Starter
Gregg
Excellent!
As Donny pointed out the high fan operates by the external wire from the horn relay. Everything is working, well that is after cleaning up the insulation goop that hardened in the connector preventing it from getting a good fit into the dash harness, justcleaned the goop in between the connectors didn't remove the goop. with it being cooler it got a bit hard.
Thanks Levon & Donny.
Gregg
70 SS Chevelle LS5
gzwhite is offline
post #7 of 12 (permalink) Old Dec 24th, 12, 10:25 AM
Levon and Donny
Best wishes for the Holiday.
Oman
oman is offline
post #8 of 12 (permalink) Old Dec 24th, 12, 11:54 AM
Donny
Originally Posted by oman View Post
Levon and Donny
Oman
To you as well Oman!
Donny
aawtech is offline
post #9 of 12 (permalink) Old Dec 24th, 12, 1:50 PM
Donny
Thanks for your help this fall on the A/C harness. Almost done with the install.
oman is offline
post #10 of 12 (permalink) Old Dec 26th, 12, 9:37 AM
Donny, if you see this plz check the thread "what is this harness and what does it go to?" I've volunteered you/AAW for several things in there, can you do all that stuff?
post #11 of 12 (permalink) Old Dec 26th, 12, 10:39 AM
Donny
Hi Tom, I have noticed it, but there was quite a bit that was being suggested to the gent. Yes, we can modify the engine for HEI and the F/L for internal reg. with no problem at all. So many folks want to try and fix and repair 40 year old stuff that has already been cobbled-up in one form or another. I am hesitant to offer a solution, because, for my money, it should just be torn out and replaced as there were too many questions and too much done to it already. When I suggest that, occasionally some members have stated that the only reason I'm saying to "just replace it" is that I'm trying to generate business for the company, and that just is not the case. More often than not, I have helped people with problems many times over without them ever spending a dime with the company that I work for. My position is that if you need to "do all that" to a 40 year old harness, it flat out needs to be replaced, period (if it's available). I will be happy to help this gentleman if he is interested in replacing things, but I just can't in good conscience help him repair this or that, and it has nothing to do with not spending money to buy our product. The hobbyist in me (remember, I own 7 of these cars myself) will not let me tell someone to repair something that I know in my heart needs to be replaced because I know that there is a potential problem brewing beneath the surface. I hope you can understand my quandary here. Again, please send him a PM and tell him to contact me direct if he wants some help and counseling on what my suggestions would be based on his wants and needs. I just hate to chime in on a repair situation when I know that it's not a good idea.
Donny
aawtech is offline
post #12 of 12 (permalink) Old Dec 26th, 12, 11:00 AM
I agree with Donny. As the old saying goes.."There is never time to do it right there is always time to do it over". I am not sure what the original poster wants to do but messing with 40 year old harnesses, trouble shooting and making modifications is asking for heartburn if you ask me.
oman is offline
This Thread is more than 2433 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
