no power to switched fuses - Chevelle Tech
post #1 of 3 (permalink) Old Sep 29th, 12, 4:45 PM Thread Starter
sam
Hey y'all,
I'm new to the forum, but i have a problem with my 67 el camino's fuse box. I have power to the constant 12v fuses but nothing to the switched fuses with the key on. The car will start and run with 12 volts to the hei and there is 12v to bothe sides of the horn relay. Any ideas?
Thanks,
red elko
red elko is offline
post #2 of 3 (permalink) Old Oct 1st, 12, 7:49 PM
Re: no power to switched fuses
Do you have a test light or a voltmeter to check for power?
What is the condition of the fuse box? These fuse boxes are notorious for getting corrosion build up on the clips that hold the fuses. Even if the fuse is good and tight in the clips, sometimes you won't get any current to pass because there is such a poor electrical connection between the ends of the fuse and the clips in the box.
Coppertop is offline
post #3 of 3 (permalink) Old Oct 2nd, 12, 2:17 AM
Also, plug to ingition swich looses connetion when wires get hot. Use the test light to see if the power is comming through the ignition switch.
Brown wire leaving ignition swich going to fuse box (12 gauge) should have 12v when key is in run position.
HotWheelsFan is offline
This Thread is more than 2805 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
