Starter Wiring - Chevelle Tech
post #1 of 18 (permalink) Old Apr 9th, 12, 12:00 AM Thread Starter
Starter Wiring
I need help wiring my Starter on my '67 Chevelle, when I had the engine in the car I was running a Point Distributor, I'm going to be putting in my rebuilt engine back in and going with a HEI distributor
From the Wiring harness I have a:
-Purple Wire (Soldered to a white wire)
-Orange Wire (going to Heater Core Motor)
-Black Wire (with White Insulation)
Can someone please tell where the wires go on the Starter I have Numbered the terminals on the starter
1967 Chevelle Oshawa Built Car
-427 .60 over, Lunati 60211 Roller cam
-Super T10 2.64
-Dana 60 3.54 Posi
1967 chevelle is offline
post #2 of 18 (permalink) Old Apr 9th, 12, 12:45 AM
Vince
Re: Starter Wiring
https://www.chevelles.com/techref/ftecref4.html
check this link out
#2 is the battery
your purple/white soldier wire goes to the "s" terminal on the solenoid.
VinceS427bb is offline
post #3 of 18 (permalink) Old Apr 9th, 12, 10:25 AM Thread Starter
Re: Starter Wiring
check this link out
#2 is the battery
Kk so the purple/white wire and the battery cable go on #2, which terminal does the Black Wire (with White Insulation) go on?
-Super T10 2.64
-Dana 60 3.54 Posi
post #4 of 18 (permalink) Old Apr 9th, 12, 10:41 AM
Re: Starter Wiring
Nothing but the battery cable goes on #2 (before 1972)
With an HEI you won't need the ballast resister shown or the cloth covered resistive wire that is coming out of the harness with the orange wire. (I don't know what the brown wire going into the gutter is.)
You also won't need anything on the solenoid's "R" terminal (#1)
post #5 of 18 (permalink) Old Apr 9th, 12, 4:27 PM Thread Starter
Re: Starter Wiring
I'm confused, if only the battery cable goes on #2 where does the purple/white wire go?, and the Black Wire (with White Insulation) go?, the Brown wire is my tach Wire
-Super T10 2.64
-Dana 60 3.54 Posi
post #6 of 18 (permalink) Old Apr 9th, 12, 4:47 PM
Re: Starter Wiring
The purple wire goes on the solenoid's "S" terminal.
I *think* "the Black Wire (with White Insulation)" that you are talking about is the "cloth covered resistive wire" that does not get connected to anything anymore.
post #7 of 18 (permalink) Old Apr 9th, 12, 4:51 PM Thread Starter
Re: Starter Wiring
oh ok thanks for clearing it up for me, so the brown wire (tach) and 12 volt source goes to the HEI distributor
-Super T10 2.64
-Dana 60 3.54 Posi
post #8 of 18 (permalink) Old Apr 9th, 12, 5:06 PM
Sergio
Re: Starter Wiring
Can't that wire just be replaced with a normal 12GA wire and used to power the electronic ignition?
Delta is offline
post #9 of 18 (permalink) Old Apr 9th, 12, 5:23 PM
Vince
Re: Starter Wiring
yes where this cloth covered wire comes out of the firewall plug and goes into the engine harness you will want to remove and splice in normal wire going to the coil and hei distributor/box as per the hei-manufacturer wiring diagram.
unless you are using a Mallory hei-distributor you most likely will need to remove the balast resistor next the coil also....
the tach wire will most likely need to be routed to your hei-distributor or box.
you will find out the wire routing in the manufacturers wiring diagram, when you have the hei-componets you intend to run...
post #10 of 18 (permalink) Old Apr 9th, 12, 7:04 PM
Re: Starter Wiring
Yes, they both go to the HEI distributor cap.
And like Vince said, you can replace that resistive wire at the bulkhead connector with a regular 14 gauge wire IF you can find the required terminal. (I got them at my Chevy dealer)
post #11 of 18 (permalink) Old Apr 9th, 12, 8:50 PM Thread Starter
Re: Starter Wiring
I have a Summit Racing Blueprinted HEI Distributors which is pretty much a stock replacement HEI there was no wire diaphram in the manual, i'm confuded because the last time i had the car out (18 years ago) i had a HEI distributor in there but when i pulled the motor i did not mark where the wires go, i remember i had to get 12 volt source to feed the HEI, i had a wire from the fuse box going to the distributor, i have removed the resistor and Accel coil off the Firewall, so i guess the cloth covered wire doesn't go anywhere? so does the Purple/ white wire go to "S" terminal?
-Super T10 2.64
-Dana 60 3.54 Posi
post #12 of 18 (permalink) Old Apr 9th, 12, 11:54 PM
Vince
Re: Starter Wiring
https://www.chevelles.com/techref/ftecref5.html
the cloth covered wire needs to be removed from firewall bulkhead and replace with a 12gauge. hei problems are caused by Insufficient wire gauge to "BAT" or "B+" terminal. You must have 12 gauge wire or thicker. GM knows this, but often cars get converted to HEI and thin wire or the old resistance wire is used. This will produce weak spark, especially at higher RPM.
Notes on wiring for an "HEI" distributor with the coil in the cap;
If you are converting from a points type distributor, you have to make sure that the "resistance" power wire is bypassed! It's best to just run a new 12-guage wire from the fuse block. This wire goes to the terminal marked "BAT" or �B+� on the distributor cap. I�m told that the average electrical draw of the HEI is fairly low, but the instantaneous draw can be quite high.� That�s why you need such a large wire feeding power to it.
There is no longer a need for the power wire that comes from the starter �R� terminal.
On most HEI's, there are three wires that come from the base of the distributor and they plug into the cap. It's a connector block and can't be plugged in wrong.
the hei distributor cap is labled with tach and +B+ terminals=connect the tach wire here and a 12vdc source that is controlled by a switch(or ignition) and you are good
you also need a good ground to engine from the battery(ground).
post #13 of 18 (permalink) Old Apr 10th, 12, 12:10 AM
Jerrod
Re: Starter Wiring
Just put a DUI HEI in my car. Not sure about the 67s but my 71 has an empty plug in the fuse block label IGN and works great for wiring in the HEI.
'71 Chevelle SS 396 4 spd
JRodSS is offline
post #14 of 18 (permalink) Old Apr 10th, 12, 12:11 AM
Re: Starter Wiring
Like I said already, 14 gauge wire to the HEI is plenty big enough!
I've converted several over to HEI.
post #15 of 18 (permalink) Old Apr 28th, 12, 11:09 PM Thread Starter
Re: Starter Wiring
I have a 14 Gauge Wire coming from the Fuse box to my HEI
-Super T10 2.64
-Dana 60 3.54 Posi
This Thread is more than 2958 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
