69 shorty fuse for dash lights - Chevelle Tech
post #1 of 3 (permalink) Old Mar 6th, 11, 6:50 PM Thread Starter
On a 69 there is a gray wire that comes off the fuse block and then branches off about 7 different ways to accommodate all thirteen dash instrument lights. Last year I added an additional 3 gauge (oil,temp,volts) panel which supports 3 lights. I tapped into the gray wire to light these and it worked just fine. Over winter I removed the dash to replace 4 burnt out dash lights. Now for the first time I had all the lights (plus the 3 add ons) working. It lasted all about 2-3 minutes-----all went dark. Okay blew the little 4a shorty fuse, replaced and tried again. This time it lasted a little longer. Okay I know I am overloading the circuit, my question is it possible to get a bigger 4a fuse so it won't burn out. If that is even possible then will I experience other problems like burnt or melted wires.
If this is not possible then can someone suggest another wire I can tap into to run these other 3 gauge lights. I was thinking about tapping the side marker lights which come on just like the dash lights, however is this even an option. I would love any input, for electrical is not a strong point of mine.
Brian69 is offline
post #2 of 3 (permalink) Old Mar 6th, 11, 6:54 PM
Ron
Re: 69 shorty fuse for dash lights
3 more bulbs won't hurt. Put a bigger fuse in say 6A.
Ron
My car is here:
bikeron is offline
post #3 of 3 (permalink) Old Mar 6th, 11, 9:34 PM Thread Starter
Thanks for the quick response. I will try it and let you know.
Brian69 is offline
This Thread is more than 3410 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
