Voltage Leak!! - Chevelle Tech
post #1 of 5 (permalink) Old Mar 2nd, 11, 10:37 PM Thread Starter
Ryan
Voltage Leak!!
Hey guys, I have a 1971 Chevelle with a 350. I re did some of the wiring 6 months ago (after an electrical fire) that included new alternator, voltage regulator, and battery, along with all the necessary wiring.
Anyway, it ran and charged great up until about a couple months ago. The car sat for a month, then when I went to start it the battery was dead. No big deal I though; I charged the battery and it started right up. However, since then the battery will die practically overnight.
I checked the amperage from the negative battery terminal to the negative battery cable with the car and everything off and it was at 70 milliamps.
Sorry for the long story, but now I'm trying to hunt down the leak. Any suggestions/tips/advice?
Thanks in advance, Ryan
Be the person your dog thinks you are.
1971 Chevelle 350
Tremec 5 Speed/4.10 12 bolt
Some pictures:
Ryan71 is offline
post #2 of 5 (permalink) Old Mar 2nd, 11, 10:51 PM
Randy
Re: Voltage Leak!!
Pull the hot wire off the alternator while checking the ammeter. Next pull 1 fuse at a time until you isolate the short. When you've found which circuit, you'll need to consult a wiring diagram to find exactly where the leakage is.
Randy
TC # 5401
67 Project SS Clone
pnugene is offline
post #3 of 5 (permalink) Old Mar 2nd, 11, 11:03 PM Thread Starter
Ryan
Re: Voltage Leak!!
This was my original plan. I have done this to my other (newer) car. My only concern for doing it to this one is the wiring is so goofy as is, I'm curious if this will narrow down my problem. The person that had the car before me did some questionable electrical work resulting in the electrical fire.
Since I've had it I've cleaned up what I could but not sure the condition of the rest.
None the less. I will try this tomorrow and let you know if it works!
Thanks!
Ryan
1971 Chevelle 350
Some pictures:
Ryan71 is offline
post #4 of 5 (permalink) Old Mar 3rd, 11, 5:06 PM
Jerry
Re: Voltage Leak!!
I agree with the above regarding tracing down your short. I would add a master disconnect switch on the neg. side of the battery. If the wiring is questionable and the car has suffered a fire in the past, I would use the switch at all times. The switches are about $10 and I use them on all my non daily drivers. Jerry
Tampa Jerry is offline
post #5 of 5 (permalink) Old Mar 4th, 11, 11:53 AM Thread Starter
Ryan
Re: Voltage Leak!!
That's a good idea. I've been disconnecting the battery every time. A switch is much nicer.
Thanks, Ryan
1971 Chevelle 350
Some pictures:
Ryan71 is offline
This Thread is more than 3419 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
