Steering Column Wiring Question - Chevelle Tech
post #1 of 8 (permalink) Old May 5th, 09, 6:50 PM Thread Starter
David
OK, part two of the wiring mystery...Ron Francis didn't have any answers for where the column wires go, except to tell me to find a factory wiring diagram and consult that...which I don't have. So, any of you fellow Chevelle owners out there who could offer help, I would sincerely appreciate it!
Sitting in the driver's seat, looking down at the wiring harness that comes out of the steering column, the colors of the wires, from left to right are: black, green, yellow, dark blue, white, light blue, and purple. The RF kit I put in has all the wires labeled, so if anyone can tell me where these wires go ( front and rear turn signals, parking lights, turn signal flasher, horn, and ground), I can easily connect them up to the RF supplied wires.
I assume black is ground, but the insulation is original, and could be "aged" brown in color? The rfeason I bring that up is a friend told me that horn wire leads are brown...don't know if this is true or not.
Thanks for any help!!
David Mauldin, 66SS, 496, six speed
David Mauldin is offline
post #2 of 8 (permalink) Old May 10th, 09, 3:59 PM
Ron
Re: Steering Column Wiring Question
If you don't get an answer here, try the Electrical and Wiring forum.
Ron
'87 Camaro IROC-Z L98
'69 300 Deluxe SS396
Founding member of
Bow_Tied is offline
post #3 of 8 (permalink) Old May 10th, 09, 6:57 PM
Steamy
Black=horn, green=Rt rear turn signal, yellow=Lft rear turn signal, Dark blue=Rt frt turn signal, Light blue=Lft frt turn signal, Purple=turn signal flasher, White=Brake lights
I'm pretty sure that's correct for a '66, the only thing I'm not positive about is the white wire for the brake lights, on a '68, it's black.
BillL
My Showroom
Ark68SS is offline
post #4 of 8 (permalink) Old May 10th, 09, 8:39 PM
Greg
BillL
White=Brake lights, power in from brake pedal switch.
Greg U
undee70ss is offline
post #5 of 8 (permalink) Old Aug 8th, 09, 12:38 AM
Another helpful post. Thanks guys.
MikesCozyCorner66 is offline
post #6 of 8 (permalink) Old Sep 7th, 09, 5:00 PM
Banned
What would cause the Purple and the Dark blue wires to short together? I have great trouble shooting skills but this has me baffled. Been through two turn signal switches now and don't want to ruin another. I cannot see anything obvious and all the wiring is Brand new from M&H. The flasher gets red hot and the purple and dark blue wires melt. Any ideas?? Anyone had this happen? Thanks for any help.
Bisquit037 is offline
post #7 of 8 (permalink) Old Sep 8th, 09, 2:27 PM
Steamy
You might want to start another post about this problem instead of tacking it onto an old post.
If the flasher is getting hot, my first impression is that the flasher is bad. They aren't made to carry a lot of current, and the contacts may be welded together.
BillL
My Showroom
Ark68SS is offline
post #8 of 8 (permalink) Old Oct 13th, 13, 2:24 AM
Hector
Another reason to use an electronic timed flasher instead of a bi-metal flasher.
My wife says size doesn't matter. But I say 454 cubic inches is about average.
66 300 Deluxe:
82 454 Truck engine
MSD A6 Digital
Mallory Billet Dist
Edelbrock E-Street EFI
Ron Francis Access 24/7 Harness
Edelbrock Performer intake manifold
MARCH serpentine Belt
Power Steering and A/C
Totally completely stock dash
Totally crap aluminum radiator
JOKER11 is offline
This Thread is more than 2321 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
