Firewall Wire Loom for a 72 - Chevelle Tech
post #1 of 8 (permalink) Old Apr 28th, 09, 12:11 PM Thread Starter
Question Firewall Wire Loom for a 72
Does anyone know where to get a wireloom for a 72? Mine was ruined in a resistor wire meltdown years ago and all I can find is the "basic" one for older models. Thanks
Robert
1972 Malibu bought from Mom for a buck in 1987. She drove a great car but didn't drive a hard bargain.....
loosend is offline
post #2 of 8 (permalink) Old Apr 28th, 09, 12:33 PM
Jonathan
Re: Firewall Wire Loom for a 72
Are you talking about a 72 firewall wiring gutter?
Two 72 Chevelle Malibus, both 350 2bbls one Placer Gold, one Midnight Bronze
Other cars:
2005 Pontiac Vibe
2005 Ford Excursion
2000 Dodge Durango
2003 Mercedes E320
2-2018 Ford Fusions
2013 Ford Fusion
Chevelle_Nut is offline
post #3 of 8 (permalink) Old Apr 28th, 09, 1:48 PM Thread Starter
Yes. That is a better word than "loom". It is the plastic gutter that is screwed to the firewall.
Robert
loosend is offline
post #4 of 8 (permalink) Old Apr 28th, 09, 3:11 PM
Jonathan
For a 72 there are no reproductions. It is definitely a different design and many OEM ones got torn or broken. In 72 they cleaned up the wiring thus the different horn relay and gutter. The pictures show a reproduction and my factory one. I cut the reproduction one and mounted it inside the OEM one and it looks as jood as new.
Name:	72 Chevelle  3-2009 009.jpg
ID:	20650   Click image for larger version
Name:	72 Chevelle  3-2009 010.jpg
ID:	20651   Click image for larger version
Name:	72 Chevelle  3-2009 011.jpg
Other cars:
2005 Pontiac Vibe
2005 Ford Excursion
2000 Dodge Durango
2003 Mercedes E320
2-2018 Ford Fusions
2013 Ford Fusion
post #5 of 8 (permalink) Old Apr 29th, 09, 9:23 AM Thread Starter
I have the same repro gutter. Did you cut the top flap off the original gutter so the repro could fit inside? Also, did you screw the repro gutter to the firewall or just sit it inside the original gutter? I wish mine was just torn or broken but unfortunately, it melted some so it doesn't look very good. Thanks for your help and ideas.
Robert
loosend is offline
post #6 of 8 (permalink) Old Apr 29th, 09, 5:27 PM
Jonathan
I cut the gutter part off of the repo gutter and it is basically reinforcing the back of the original and is what is bolted to the firewall. Because of the wires and original gutter you cannot see it. I decided not to glue the two together, did not think it was necessary.
Other cars:
2005 Pontiac Vibe
2005 Ford Excursion
2000 Dodge Durango
2003 Mercedes E320
2-2018 Ford Fusions
2013 Ford Fusion
post #7 of 8 (permalink) Old Nov 25th, 13, 5:34 PM
Jonathan: if you're still around, can you elaborate on what you did? Putting one inside the other? My gutter is cracked. It's the same as ion the bottom of the picture, is that the style that is no longer available? Putting the new one inside still leaves me with a cracked gutter for the world to see.
1972 Chevelle - 350 - TH350
Va72Chevelle is offline
post #8 of 8 (permalink) Old Nov 25th, 13, 9:40 PM
Jonathan
I am here. Trying to remember.... The gutter usually breaks at the screw holes, by reinforcing it you keep it from falling. The 72s gutter is not reproduced and is a 1 year item so it may have a crack for the world to see but with a little work you can make it look good.
Other cars:
2005 Pontiac Vibe
2005 Ford Excursion
2000 Dodge Durango
2003 Mercedes E320
2-2018 Ford Fusions
2013 Ford Fusion
This Thread is more than 2381 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
