64 Wiring to horn relay - Chevelle Tech
post #1 of 9 (permalink) Old Jun 2nd, 20, 6:58 AM Thread Starter
Bmiller
After replacing front wiring harness, I am starting to hookup wires to the horn relay. I am a little uneasy about how it was before so want to double check before just booking up wires. What wires hook up we’re on horn relay? One wire comes from battery and other red wires from harness. Also there is a black wire which was not even hooked up before. Any help?
Bmiller
bmiller84 is offline
post #2 of 9 (permalink) Old Jun 2nd, 20, 8:50 AM
Re: 64 Wiring to horn relay
All off the red wires hook to the buss bar, the black wire is your horn contact from the steering wheel and goes to a separate terminal on the relay. The green wires are the horns.
oldcutlass is offline
post #3 of 9 (permalink) Old Jun 2nd, 20, 9:54 PM Thread Starter
Bmiller
Ya the horn plug is pretty straight forward, itís the black wire that I am unsure of?
Bmiller
post #4 of 9 (permalink) Old Jun 3rd, 20, 12:33 PM
Look at the side of the horn relay/ junction box. Pins 3 and 5 are where all your red wires are attaching. Pin 1 is the green wire to the horns, black should connect to pin 2.
*Jeff*
LQ4 / T56 Swap
Hotwire is offline
post #5 of 9 (permalink) Old Jun 3rd, 20, 2:24 PM
Maybe this will help. I took this pic before disassembling my wagon...
64 2 door Wagon Build thread
67 2 door Sedan LS1 T56
Pete 67 is online now
post #6 of 9 (permalink) Old Jun 3rd, 20, 8:42 PM
Just throwing this out but with the terminals with the fork ends I would think they would go under the screws on the buss and any terminal with a female end would plug into specific male terminals under the relay. I could be wrong as I cannot see the underside of the relay but I do not remember seeing any Chevrolet horn activation wire terminated with a fork terminal. All I have seen are horn activation wire ends with a 1/4" female connector encased in a plastic housing.
Could the small black with the fork be for an optional ammeter ?. Maybe the harness is made to use an external shunt for an ammeter circuit ?.
Don't go assuming anything because once you let the smoke out of the wire, that's a no good.
If you want to test the black wire while it's not connected to anything, an ohm meter should show a ground when the horn button is depressed.
Always working on something:
Jim Streib is online now
post #7 of 9 (permalink) Old Jun 5th, 20, 9:22 PM
Pretty sure Jim is right on this. Checked schematic and higher end Malibu ss had ammeter connection. Just checked my car, looks like the horn connector has horn power and button connection in same plug.
*Jeff*
LQ4 / T56 Swap
Hotwire is offline
post #8 of 9 (permalink) Old Jun 6th, 20, 9:09 AM Thread Starter
Bmiller
Ok thanks for pics and info. Yes my horn connections are on same plug. So that makes since If black wire is for ammeter. I left that unplugged and taped off as my gauge is already fried and not hooked up. Going to start it up today and see how it goes
Bmiller
post #9 of 9 (permalink) Old Jun 6th, 20, 10:04 AM
Good luck!!
Here's the schematics if you need them:
Passenger compartment:
https://drive.google.com/file/d/1ojE...ew?usp=sharing
Engine compartment:
https://drive.google.com/file/d/11dk...ew?usp=sharing
*Jeff*
LQ4 / T56 Swap
Hotwire is offline
