be sure to wire this device directly to the battery! - Chevelle Tech
 3Likes
  • 1 Post By 69SS454
  • 1 Post By 69SS454
  • 1 Post By oldcutlass
post #1 of 7 (permalink) Old May 27th, 20, 2:11 PM Thread Starter
Randy
Just about everything I add to my Chevelle wants a direct line to the 12v post on the battery. Stereo, EFI, cruise, you name it, it wants a dedicated circuit. I know that good clean power to these accessories is important, and I want to make sure they have the power to do what they are supposed to do. But I don't want 17 wires hanging off my battery post. A friend mentioned using a Ford fender relay as a power post. Some guys have run accessories off the horn relay. What have some of you all done to make a clean access to battery power in the engine compartment?
thanks,
Rat
1970 Chevelle Malibu. Red. Did it come in another color?
rattracer is offline
post #2 of 7 (permalink) Old May 27th, 20, 2:25 PM
Re: be sure to wire this device directly to the battery!
I know what you mean. It gets ugly very quickly. I found these while searching 'on the line'. They are kind of like what new cars use.
https://www.littelfuse.com/products/...case-bmzf.aspx
https://www.projecta.com.au/battery-...ution-terminal
rattracer likes this.
69SS454 is offline
post #3 of 7 (permalink) Old May 27th, 20, 3:17 PM
Ken
Add one of these xtra fuse panels. It connects to the battery and gives you 8 additional fuses and wires and has 2 relays.
https://www.summitracing.com/parts/prf-70217?rrec=true
ken70ss396 is offline
post #4 of 7 (permalink) Old May 27th, 20, 3:26 PM
I have used those a lot. They work great under the dash for adding circuits but I think he wanted higher current connections.
lucifershammer likes this.
69SS454 is offline
post #5 of 7 (permalink) Old May 27th, 20, 6:07 PM
I prefer to setup a separate power distribution panel that's connected to the battery and not run a bunch of wires directly to the battery cable lugs. You can buy them as fused or terminal strip type units.
Kirk's67SS likes this.
oldcutlass is offline
post #6 of 7 (permalink) Old May 27th, 20, 8:43 PM
Bruce
My '69 has a junction block "behind" the battery (attached to the firewall). Any electrical that "needs" to be directly attached to the battery gets hooked into the electrical system at that junction block. There's a secondary power feed that comes off the positive battery cable, follow that feed wire to the junction block.
Our You Tube Vids:
NickeyChevelle is offline
post #7 of 7 (permalink) Old May 27th, 20, 9:18 PM
Frank
On my ride, on the driver's side I tapped off the horn relay for three relay-triggered circuits (headlight low, headlight high, ignition) each protected with a self-resetting circuit breaker. On the passenger side, other always-on circuits tap off the junction block behind the battery, as described by Bruce in the previous post.
With the factory wiring setup, the alternator provides power directly to the horn relay and battery junction terminal through 10 gauge wire. This was adequate for a 62 amp generator. I would recommend upgrading the alternator feed wire and battery-to-horn-relay wire if much more current is drawn from the added terminals.
-Frank
1970 Chevelle Malibu purchased new in 1970
355 SBC, XE262H cam, Performer RPM heads, MSD HEI, TH200-4R trans, 3.55:1 Posi, digital gauges, QA1 coilovers
Malibu70 is offline
