Wire harness - Chevelle Tech
post #1 of 3 (permalink) Old May 24th, 20, 3:04 PM Thread Starter
mark
Wire harness
Just finishing up a heater core on my daughter's 2011 jeep liberty. Coolant saturated carpet on both side on a little in rear. Wiring harness under seats sit in valleys that were sitting in coolant. My question is how far do I have to go to clean wires. Is wiping them down good enough? Soap and water? Thanks. Mark
70 SS LS6
LIC #73
TC #3594
wannarun70 is offline
post #2 of 3 (permalink) Old May 24th, 20, 3:09 PM
Randy
Re: Wire harness
If the insulation is unbroken, wipe them dry. Any connectors that got wet will need more attention. Disconnect and spray the connectors with WD40 or similar to displace any moisture and inspect the pins & sockets for any corrosion.
Randy
TC # 5401
67 Project SS Clone
pnugene is offline
post #3 of 3 (permalink) Old May 24th, 20, 3:58 PM Thread Starter
mark
Re: Wire harness
Thanks Randy
70 SS LS6
LIC #73
TC #3594
