1970 blower motor troubleshoot - Chevelle Tech
post #1 of 7 (permalink) Old Mar 25th, 20, 8:49 AM Thread Starter
Trying to figure out why my blower motor donít work. It was new motor when i did restoration and Iíve never been able to get it to work. I tried using a jumper direct to see if it works..
The ground to the blower motor is good but if i put a jumper to try and power it the jumper sparks like crazy and the fusible link glows red. Instead of jumping from battery to blower i am jumping the red wire and purple wire in the pigtail thatís connects to relay. Now let me ask this also. If my heater box resistor is bad would that cause this to spark? But yesterday i tried same thing but went from battery to blower motor and it sparked too. Really struggling here. Lol
Ryan T is offline
post #2 of 7 (permalink) Old Mar 25th, 20, 10:45 AM
Re: 1970 blower motor troubleshoot
Are you sure the blower impeller isnít restricted in some way? Did you test the blower before it was installed?
I purchased a new blower motor with impeller and comparing with the take out, had a deeper impeller, which would have contacted metal.
Ed C.
70 SS Gold L34 Auto
57 Belair hardtop project
Always looking
EdCarpenter is offline
post #3 of 7 (permalink) Old Mar 25th, 20, 2:15 PM Thread Starter
No Iím not and was hoping to avoid ripping front fender apart to pull the blower motor but it looks like that is going to have to happen.
Ryan T is offline
post #4 of 7 (permalink) Old Mar 25th, 20, 9:23 PM
I too had to change out my blower motor on my 70. Worked fine out of the car, but was too noisy once installed. I had to be careful since everything was fresh. I took out the all the inner fender bolts except the 3 or so that hold the battery plate and at the rad support. Used a 3 foot piece of 2Ē pvc pipe to pry the inner fender away from the blower area (wheel was off). This allowed enough room to pull the motor out without causing damage to paint. The inner fender may deform a bit, but will pull back once you re-fasten it. Mine was an AC car.
Ed C.
70 SS Gold L34 Auto
Always looking
post #5 of 7 (permalink) Old Mar 26th, 20, 2:16 PM Thread Starter
Did you have to put a new blower in or was there something else you did? What made it work finally in the car.
Ryan T is offline
post #6 of 7 (permalink) Old Mar 26th, 20, 6:40 PM
The blower impeller rattled when installed. I removed the blower to replace it with aftermarket. The aftermarket impeller shaft and impeller was 1/2 inch deeper than the original. Luckily I had a couple of old take offs in my inventory. Tested, cleaned and painted one of them and installed it.
Now works quietly.
Ed C.
70 SS Gold L34 Auto
Always looking
post #7 of 7 (permalink) Old Mar 27th, 20, 7:27 AM Thread Starter
Gotcha, thanks, looks like i will remove and check off the car and also make sure it moves freely.
Ryan T is offline
