Tail lights not working. 1972 - Chevelle Tech
 4Likes
  • 1 Post By LevonH
  • 1 Post By Srober40
  • 1 Post By oldcutlass
post #1 of 14 (permalink) Old Feb 15th, 20, 7:37 PM Thread Starter
Hey gang,
Newbie here. Have a question.
Rear tail lights do not work when lights are on. Brakes lights and turn signals work. Headlights and front markers work.
Any suggestions where to start?
Srober40 is offline
post #2 of 14 (permalink) Old Feb 15th, 20, 7:48 PM
Al
Re: Tail lights not working. 1972
License plate light. Got power there? Got power to the side marker lights? Taillights are on the same circuit.
Ground your test light to the bumper, pull the lightbulb and probe both contacts. See any power there. One should show constant power with just the taillights on.
BROWN wire is going to be the power wire for your taillights and license plate light. All on the same circuit.
If youR parking lights are working that means you are getting power from the headlight switch to the park lights and taillights. Both are supplied from the same circuit from the headlight switch LEADING THROUGH A BROWN WIRE.
Check your fuses with a test light on both sides of the fuse.
davewho1 likes this.
DUTCH MAX HEADWORK is offline
post #3 of 14 (permalink) Old Feb 15th, 20, 8:50 PM
Levon
Have you tested the bulbs?
Levon Hovagimian
Team Chevelle #279
1966 427 Corvette SOLD
Priddis Greens, Ab. Canada
LevonH is offline
post #4 of 14 (permalink) Old Feb 15th, 20, 9:15 PM Thread Starter
Bulbs seem to be o.k. I didnít see broken filaments.
Need to check the side markers and license plate light now that it is dark.
Thanks for the replies.
I am learning as I go. I have a lot to learn.... I do use the search function on the forum. Lots of great info on this site.
I went and got new bulbs for all of the lights also. I figure if I donít need them, I will eventually.
I have lots of bugs to work out on the car. Mostly minor. Focusing on the ones needed for inspection first.
Srober40 is offline
post #5 of 14 (permalink) Old Feb 16th, 20, 1:13 AM
Kevin
You say brake lights work. Do the turn signal indicators on the dash light up when you press the brake pedal? If so, then you have a bad ground at the taillights.
2017 SS
1972 El Camino Custom
2005 SSR 6-speed
1999 Silverado
SSR71 is offline
post #6 of 14 (permalink) Old Feb 16th, 20, 8:07 AM
Check the wiring harness connections. There's one around the back seat.. I cut the plugs off then solder and tape the wires..
Also look for the grounds and clean them up by removing the screws, wire brushing the area, then connect them back up and cover them in either wheel bearing grease or paint..
hydro462 is offline
post #7 of 14 (permalink) Old Feb 16th, 20, 10:20 AM Thread Starter
Bad ground and a bad bulb. All working now. Next step is to replace all of the bulbs since I have them.
Next step is to figure out how to get the horn to work....
Srober40 is offline
post #8 of 14 (permalink) Old Feb 16th, 20, 10:35 AM
There is no reason to replace all the bulbs, just remove them and clean the sockets. The horn/s are powered by a relay that is looking for a ground supplied from the black wire fed from the horn button. The relay has 12v on it at all times and once it gets a ground signal it provides 12v to the horns. So you need to see which half of the circuit is not working, the ground side or the plus side.
oldcutlass is offline
post #9 of 14 (permalink) Old Feb 16th, 20, 8:06 PM Thread Starter
Thanks.
The horn has a good ground. The steering wheel is a 4 spoke. I think it is missing an insulating ring and a plunger piece.
When I push the plunger in and ground it the relay clicks.
Need to check the wire running from the horn to the relay next.
Srober40 is offline
post #10 of 14 (permalink) Old Feb 16th, 20, 10:21 PM
If the relay clicks your half way there. Make sure there is 12v going to the terminal that the horn wire is hooked to. Then follow that wire and see where the 12v is lost.
post #11 of 14 (permalink) Old Feb 17th, 20, 8:42 AM
Give the bulb a spray of WD before putting it in the socket, this also works for vacuum and water hose connections..
hydro462 is offline
post #12 of 14 (permalink) Old Feb 20th, 20, 8:19 PM Thread Starter
Thanks guys.
On the horn wire, what gauge is the right gauge to replace it from the horn to the relay?
Hydro462, I see you are from Pittsburgh. I was born and raised there. Spent the first 38 years of my life there. Grew up in the south hills.
Srober40 is offline
post #13 of 14 (permalink) Old Feb 21st, 20, 10:01 AM
Originally Posted by Srober40 View Post
Thanks guys.
There are a couple of us here! Pittsburgh, the #1 city in the country (to leave )
I've always been a east suburbs guy, out in Greensburg now.
Pioneer4x4 is offline
post #14 of 14 (permalink) Old Feb 21st, 20, 8:15 PM Thread Starter
Hey Pioneer.
I really like Pittsburgh. Great place to grow up and live. Loved the outdoor opportunities for hunting and fishing. Miss my friends and family. The winters are tough though.
Work took me to Texas and I like it here. Love the heat and mild winters.
Once I moved south I lost my tolerance for cold weather....
Srober40 is offline
