Wiper and headlight questions for '68 - Chevelle Tech
 2Likes
  • 2 Post By any4xx
post #1 of 7 (permalink) Old Feb 15th, 20, 12:42 PM Thread Starter
Hey everyone,
I recently finished a rebuild on a '68 in which I rewired the car using American Autowire's kit. I have a couple questions after the job is done...
1) Can someone explain the two settings on the wiper switch? I'm assuming there's no delay and it's just high-low, but mine seems to wipe intermittently. I'm wondering if the switch is bad or if I just misunderstand how it's supposed to work.
2) This is a really dumb question and one I should have gotten answered before I wired the car, but are the high beams supposed to be on the inside or the outside? I left enough slack in the wires to switch them, or at least I intended to.
Thanks in advance for any assistance!!
1968 Chevelle 2-door coupe restomod... 496ci BBC, Holley 950, T-56 Magnum, Dana S60, and an idle that shakes the ground.
Gauge is offline
post #2 of 7 (permalink) Old Feb 15th, 20, 1:05 PM
Re: Wiper and headlight questions for '68
Wipers are 2 speed, no delay. So they should wipe at slow steady pace setting 1 and much faster on setting 2.
Headlights. Low beams on outside. When switched to high beams, all 4 should illuminate.
Good luck!
Scott W.
Electrical Engineer
700R4
This is how we roll:
red68chevL is offline
post #3 of 7 (permalink) Old Feb 15th, 20, 4:34 PM Thread Starter
Good luck!
Wow, you just cleared up such a misconception I had by adding on the part about when all four should illuminate. I was thinking this was like a modern car where all lights were on when you had low-beams and the high-beams would end up with just 2 lights. So, not only do I have my low beams on the inside, I have been driving around with the high beams on all the time (aimed down like low beams, though). And, this left me with two confusing situations: The red light was on in the dash all the time, and the "high beams" (actually, the low beams) would basically point at the ground. My expectation of how this would work was 100% backwards!
I guess the wiper switch is also an issue because it's intermittently working.
Thanks for the help!!!
Gauge is offline
post #4 of 7 (permalink) Old Feb 16th, 20, 10:57 AM
To add to the confusion, and hopefully you already got this right; ‘68 had different wiper motors and switches depending on whether your car has hidden wipers or not.
red68chevL and jeffs68 like this.
any4xx is offline
post #5 of 7 (permalink) Old Feb 16th, 20, 10:44 PM
Terry
Thumbs up Re: Wiper and headlight questions for '68
This is good info, Thanks, Tom. Terry
68-13427 is offline
post #6 of 7 (permalink) Old Feb 16th, 20, 11:42 PM
Al
The power source for your wipers goes directly from the fuse to the wiper motor and does not run through the switch. The switch needs to be grounded to the dash and the switch itself closes the ground circuit for each speed and park cycle. The ignition switch must be on to show power to the fuse and wiper motor.
DUTCH MAX HEADWORK is offline
post #7 of 7 (permalink) Old Feb 17th, 20, 8:16 PM
I might add that the switch for the hidden wipers is usually higher priced than the standard wiper switch.
70 El Camino SS 396
68 GTO (Thanks Mom)
06 Silverado
07 SRX
OO52 is offline
