Dakota Digital - Page 4 - Chevelle Tech
 24Likes
post #46 of 67 (permalink) Old Mar 30th, 20, 7:27 PM Thread Starter
Pat
Re: Dakota Digital
Originally Posted by Cheveezy View Post
They both look great but I don't care for the huge clock for the RTX plus it only goes to 120mph 😂
Leaning towards the HDX as I want to change up the look...then would just need to decide on face color..
Pats70ss is offline
post #47 of 67 (permalink) Old Mar 30th, 20, 7:41 PM
Re: Dakota Digital
I like the HDX.
I chose the black face with white backlighting and I love it. I really wanted a gauge that would look great and be easy to read during night time driving.
Youtube Channel.
Instagram:
Twitter:
-SS454- is offline
post #48 of 67 (permalink) Old Mar 30th, 20, 8:10 PM Thread Starter
Pat
Re: Dakota Digital
Originally Posted by -SS454- View Post
I like the HDX.
Chris,
I think the option you have looks great! probably will be the way I go...I "think" the whiteface would look good.. I KNOW the blackface would
-SS454- and shovelrick like this.
Pats70ss is offline
post #49 of 67 (permalink) Old Mar 30th, 20, 8:38 PM
Troy
Re: Dakota Digital
Originally Posted by any4xx View Post
When I built my El Camino my initial plan was to go with AutoMeter gauges. But after pricing out everything I wanted the cost was the same as the HDX system. Plus the Ď68 has the ridiculous square gauge pods so Iíd have to be fabricating quite a bit to get everything I wanted to fit. I was actually reluctant to go with the DD stuff over the good old round analog gauges. But now that Iím there, Iím spoiled. For me, the best part is being able to set warning points for every sender and senders can be added very easily. I decided as an afterthought to add a transmission temperature gauge. Plug in the add-on module and itís done. I later switched to a GPS speedometer and it was an easy plug-in. I donít even need to have a particular gauge displayed to get a warning. I can have no sub-gauges displayed but if I get an overheat condition I get a red glow and even an audible alarm if I want.
To each, his own. Iíd love to have a set of AutoMeter gauges in this car. But the shape of the dash just makes it too difficult.
How is that GPS speedo? I'm close to putting my car together and this is something I have to install. I also got the ambient air temp sensor and compass ( I believe ) that's part of the GPS bim.
Being as I'm going LS engine and running a GM computer, I don't have to add any sensors just plug into the OBDII port. I get tach, oil, water, and volt. Transmission gear location for automatic. And TPMS if you want.
Sent from my SM-T720 using Tapatalk
66 CHEVELLE
senna is offline
post #50 of 67 (permalink) Old Mar 30th, 20, 10:06 PM
Re: Dakota Digital
if you change tires often (street tires to drag tires or whatever) then I definitely recommend going with the GPS speedo bim. I will likely do that upgrade at some point.
senna likes this.
Youtube Channel.
Instagram:
Twitter:
-SS454- is offline
post #51 of 67 (permalink) Old Mar 31st, 20, 1:40 AM
Ken
Re: Dakota Digital
I like the HDX.
Good choice -- same here with my HDX. My mechanic and I chose the whitee backlighting with red needles when he first finished the install. I still haven't played with some of the other color combinations.
67 Chevelle Malibu, ZZ4 350 crate engine, TH350, FiTech EFI, Vintage Air, Dakota HDX dash, FlowMaster exhaust,
17" Rally style wheels, Redline tires
darksky is offline
post #52 of 67 (permalink) Old Mar 31st, 20, 2:20 AM
Re: Dakota Digital
I only have the VHX gauges as I wanted to stay somewhat original looking. It's crazy how much of a difference in makes in the driving experience at night when the gauges are crystal clear. I love the fact you toggle all sorts of info into the digital read outs.
I would say it has been by far my most satisfying upgrade.
Youtube Channel.
Instagram:
Twitter:
-SS454- is offline
post #53 of 67 (permalink) Old Mar 31st, 20, 6:36 AM Thread Starter
Pat
Re: Dakota Digital
The VHX would probably be all I need, I am not a techy or much of a tinkerer with all the features stuff has. I am having a hard time justifying the extra 400-500 bucks just for more bells and whistles that I would probably never use.
Pats70ss is offline
post #54 of 67 (permalink) Old Mar 31st, 20, 6:44 AM
Re: Dakota Digital
One thing about the HDX is that the buttons are integrated into the dash. With the VHX, you have to install the two buttons somewhere else.
Not a big deal, but just one more little nicety of the HDX.
Another thing about the HDX is I believe the text/notification display is a little more comprehensive and customizable than the VHX version.
If you have a sweep dash, the HDX and VHX versions have the tach and speedo locations swapped. The temp and volts gauge locations are also swapped. The HDX gauge sweeps are slightly larger than the VHX gauge sweeps.
I have the VHX version sweep version (HDX wasn't a choice when I bought mine - not sure I would have bought HDX either though.)
-SS454- likes this.
lucifershammer is online now
post #55 of 67 (permalink) Old Mar 31st, 20, 8:09 AM Thread Starter
Pat
I hate decisions! Lol
Pats70ss is offline
post #56 of 67 (permalink) Old Mar 31st, 20, 10:23 AM
Re: Dakota Digital
I know Iíve already chimed in. Iíve got the HDX in my Ď68. Their new series (canít remember what they call it) that more closely resembles the stock gauges looks to have only one information ďwindowĒ where the HDX has two. I personally like to have quite a bit of information displayed. Unless Iím just not seeing it right the HDX seems to be able to give you the most information.
-SS454- and B52bombardier1 like this.
any4xx is offline
post #57 of 67 (permalink) Old Mar 31st, 20, 2:05 PM Thread Starter
Pat
Re: Dakota Digital
in the end I will probably pony up the extra and get the black face HDX. Better to have features I wont need to not have something.
as I said I will make it worth someone's while to come and spend a weekend this winter and help me install this
Just hope the world is back in a more normal place by then...
Pats70ss is offline
post #58 of 67 (permalink) Old Apr 17th, 20, 4:47 PM
Re: Dakota Digital
Wow, what a timely thread I just stumbled across! I have in my possession the black face Dakota Digital HDX series gauges for my '66. I also ordered the GPS-50-2 for GPS speed, compass, altimeter and clock, and the cheap add-on SEN-15-1 for air temperature.
Just got the dash all blown apart. I was pretty anxious about this, but in the end if was very straightforward. Took me about 2 hours, and I was being slow and bagging and labeling all the bolts, screws etc. and taking pictures. (I've since removed the heater control cables to get it out of the way).
I've cleaned out tons of old wiring from radios, old gauges, etc. Now I'm ready to start putting it back together; bought some sound/heat suppressor mat for the firewall and underside of the dash. New dash pad, all new dash chrome, etc. The install of the HDX seems *very* easy. Just a wire for battery power, accessory power, ground and that's about it. Then connections for each gauge.
I specifically came across this thread while searching out where to mount the control boxes. I saw the one photo for mounting the control box above the glove box. Not sure if that's possible on the '66...
So that's what I'd like to know: Where did you guys with '66-'67 Chevelles mount the control boxes? From reading the instructions, it seems there may be times when you have to access the control box to push button(s) on them?
And what did you do with all the old wiring connections for the gauges, and the wiring for the dash lighting? Cap them off, remove them...? I was thinking of using one of the gray dash light wires to wire to the control box for indicating when the lights come on (they say to tap into the taillights, but this way seems the same).
I'm excited to get it back together and try it out.
1966 Chevelle SS, 355 V-8, TH-350.
Gunn317 is offline
post #59 of 67 (permalink) Old Apr 17th, 20, 5:02 PM
Re: Dakota Digital
Hello Tom,
Except for a short length of dome light wiring, every inch of other wiring in my El Camino got removed and discarded. In went an American Auto Wire "Classic Update" harness and my SS-style HDX gauges lashed up to that new wiring very nicely.
My main HDX control box is down and to the left of the AC/heater controls sort of above the radio. My transmission control "PRNODD21" module is to the drivers side of the glove box. It could go on top of the glove box but my LS engine powertrain control module occupies that spot. I'm not running the GPS speedometer or any of their other "BIM" devices.
Gunn317 likes this.
B52bombardier1 is offline
post #60 of 67 (permalink) Old Apr 18th, 20, 1:19 PM
Re: Dakota Digital
Originally Posted by B52bombardier1 View Post
Hello Tom,
Wow, that American Auto Wire harness is really nice! But I will have to wait on that...maybe next time the dash is apart when I add air conditioning. Couldn't afford any more for now!
Gunn317 is offline
