70 horn relay wiring mystery - Chevelle Tech
 2Likes
post #1 of 33 (permalink) Old Dec 13th, 19, 4:58 PM Thread Starter
Adam
Fellas, I'm a bit confused on the wiring for my horn relay.
Picked up a restored 70 Chevelle about 2 months ago. The PO claimed the horn worked after it was restored. It hasn't worked while in my possession. I've attached a picture of the relay. The blue arrow is the incoming wire from the horns (which are new and work when direct to 12v). The red arrow is for the ground wire coming from the steering column. I've haven't popped the horn button off yet, but everything looks fairly new. So, my question is about the 3 different red wires going to the two terminals. Does this wiring look right? I though hitting the horn just grounded the circuit, through the relay. I would only expect one red wire from the battery, and the wire from the steering wheel on the opposite terminal. This doesn't appear to be the case on my relay. The relay doesn't click at all, even with power on. So, does this mean a wiring issue at the relay, bad relay, or issue at the steering column? Seems pretty basic, but any ideas??
Additionally, from my research, the pink/black wire is the key buzzer, which also does not work. This may be unrelated (not installed, never worked, etc.) Would that be a factor in why the horn doesn't work?
1970 Chevelle 454, 4 spd Muncie, 12 bolt, 3.31, AC, PS, PB, Ridler 695, Nitto 555
vtchopperdude is offline
post #2 of 33 (permalink) Old Dec 13th, 19, 5:29 PM
Re: 70 horn relay wiring mystery
Term #1 should be wired to the horns
Term #2 should be the ground wire fed from the horn button on the steering wheel
Term #3/5 Should have a bus bar between them and have 3 red wires, 1 from the battery, 1 from the alternator, and one to the bulkhead connector or fuse box.
Term #4 is the key minder
To test, measure 12 v at 3/5 terminal, ground 2 terminal to activate relay for the horns to blow. Ground terminal 4 to activate the key minder. If any of the above fails troubleshoot accordingly.
oldcutlass is offline
post #3 of 33 (permalink) Old Dec 13th, 19, 6:34 PM Thread Starter
Adam
Thanks for input! So from you info, all the red wires (battery, alt, fuse box), are correct by being attached to the bus connector. But, the wire from the horn switch is also on the bus connector, which would be incorrect according to your info. So, the horn switch wire is in the wrong spot...? Did this blow the relay you think?
post #4 of 33 (permalink) Old Dec 13th, 19, 10:08 PM
Something else to TEST. When I restored my 70 with power windows, I installed a new relay, OH SH!T the windows did not work, Used the OLD relay, WOW windows work.
I had to solder a wire from the base of the NEW relay to the metal cover, WHY? The old relay was 100% grounded, The new relay was not grounded.
After I soldered a wire from the tin cover to the base all is well.
I never expected the base was not grounded???????????
Robinls5 is offline
post #5 of 33 (permalink) Old Dec 13th, 19, 10:09 PM
The column horn button wire being on the hot bus bar would be a dead short if the horn button was pressed.
It would either blow the fusible link or burn the horn wire into.
post #6 of 33 (permalink) Old Dec 13th, 19, 10:21 PM
As Dean stated with the horn wire tied to 12v, when the horn button is activated there should have been sparks as its a dead short. I would say that lucky for you the horn circuit from the relay back to the horn switch has an open somewhere.
post #7 of 33 (permalink) Old Dec 14th, 19, 10:19 AM Thread Starter
Adam
Agreed that it is connected wrong. No sparks or anything when hitting the horn, so must be (hopefully) a blow fuse. Is that in the fuse block under the driver side dash or located elsewhere?
post #8 of 33 (permalink) Old Dec 14th, 19, 11:35 AM
If like an original 70 the fusible link coming off of the positive battery cable is what feeds the bus bar. (Not much in the picture looks like original though)
Need to see if the bus bar has 12 volts and if the wire coming from the horn button is ground when the horn button is pressed.
post #9 of 33 (permalink) Old Dec 14th, 19, 11:35 AM Thread Starter
Adam
UPDATE: The large black wire is actually not the horn switch wire. I traced it over to the heater control unit, but it wasn't plugged into anything. So, I'm not sure why it's there. But, I did find the horn switch wire. It was tucked away, and I plugged it in, and BOOM, the horns are blaring. So, that tells me that something is completing the circuit elsewhere. Again, the horn button on the steering wheel looks fairly new, and is not stuck. Could the wires get easily pinched or crossed under the button? I'm going to go attempt to pull it off right now. However, it looks like the horn switch wire was deliberately tucked away. It doesn't look as if it just fell off the contact. I wonder if when they were restoring it they had this same problem with them continuously blaring and couldn't figure out where it was grounding...???
post #10 of 33 (permalink) Old Dec 14th, 19, 11:39 AM Thread Starter
Adam
Before I got pulling this horn button off and tearing something up, what would my issue be here?? The plunger/spring mechanism is too long and continuously making contact under the horn button?
post #11 of 33 (permalink) Old Dec 14th, 19, 11:42 AM
So the "horn switch" wire is grounded without the horn button being pressed then?
post #12 of 33 (permalink) Old Dec 14th, 19, 11:54 AM Thread Starter
Adam
Yes. When I take the horn switch wire and plug it into the relay, the horns continuously go off. The steering wheel horn button is not stuck. I wonder if there was an installation error. I did some more digging, and I found a post about trimming the horn button contact pin. If that pin is not trimmed, would this cause the circuit to always be complete and horns continuously blaring?
post #13 of 33 (permalink) Old Dec 14th, 19, 12:10 PM
Randy
Pull your horn button off and plug back into the relay. If the horns don't blow, then your problem is at the horn contact on the steering wheel. If they do blow, then the horn wire is pinched somewhere to ground.
Randy
TC # 5401
67 Project SS Clone
pnugene is offline
post #14 of 33 (permalink) Old Dec 14th, 19, 12:23 PM Thread Starter
Adam
Is there a trick to pulling the horn button off?? I don’t want to pry on it too hard.
post #15 of 33 (permalink) Old Dec 14th, 19, 12:30 PM
Post a picture of the steering wheel
