Last unknown plug - Chevelle Tech
 4Likes
  • 1 Post By RealRed70
  • 2 Post By bdubya
post #1 of 7 (permalink) Old Dec 6th, 19, 6:24 PM Thread Starter
Last unknown plug
Any idea on where this plug goes? Its near the column harness. Car is a '70. Was a 307 auto on column, no a/c. Already found wires for clock and cig lighter. Has factory U14 gauge package.
Thanks.
1970 Chevelle Malibu
bdubya is offline
post #2 of 7 (permalink) Old Dec 6th, 19, 8:39 PM
Re: Last unknown plug
Could it have come out of the connector that is used for a console. It would be a black plug with a gray, white and orange wire in it. Yours may be missing the orange wire.
David Bates likes this.
RealRed70 is offline
post #3 of 7 (permalink) Old Dec 6th, 19, 8:42 PM
Does it have 12 volts? Orange is typically a source for things that always require power - courtesy/dome lights, clock, etc.
jim
Jim's69Ragtop is offline
post #4 of 7 (permalink) Old Dec 6th, 19, 9:12 PM
Even though the car came as a column shift, if someone put that gauge dash in it, it could be from the console plug in the dash harness.
post #5 of 7 (permalink) Old Dec 6th, 19, 9:17 PM
The only other orange wire in that area would go to the brake light switch.
post #6 of 7 (permalink) Old Dec 6th, 19, 10:27 PM Thread Starter
RealRed, you are correct, it somehow got yanked out of the console plug. Thanks!
David Bates and LeoP like this.
bdubya is offline
post #7 of 7 (permalink) Old Dec 7th, 19, 11:58 AM
Just bend the small tab on the terminal up slightly and simply slide it back into the connector until it locks in.
