Windshield Washer Pump Issue - Chevelle Tech
post #1 of 17 (permalink) Old Nov 10th, 19, 9:04 PM Thread Starter
Marco
Hi guys,
72 Skylark.
I replaced my windsheild washer pump with this unit:
https://www.summitracing.com/parts/opg-ch26136/
The unit now actuates but does not move much water. I hear the thing clicking and trying to move the fluid but almost nothing comes out.
I am using the original wiper motor.
It has probably been a long time since aasher fluid flowed.
I did blow out the lines to clear them.
Thoughts?
Thanks in advance!
mromaus is online now
post #2 of 17 (permalink) Old Nov 11th, 19, 10:06 PM
Re: Windshield Washer Pump Issue
Suggest blowing in the windshield washer tank while someone else pushes the button. This will pressurize the tank forcing fluid into the lines.
Or put the reservoir up higher than the pump so gravity helps in priming. Or there is a less optimum option, just suck on the hose like your trying to get gas out of your tank. But I would use plain water if your going to do this method at least until the lines are filled and its pumping like you want it too. There may not be enough vacuum from the pump to pull the fluid up to the pump. Once the lines are filled, you shouldn't have a problem.
Jayhawk500 is offline
post #3 of 17 (permalink) Old Nov 12th, 19, 1:49 PM
I had the same issue this year when replacing my Washer Pump on my 69 Chevelle. I returned the Pump for a replacement, and the replacement performed the same way. Clicking but not pumping. It looked like there was some issue with the teeth not engaging with the pawl. I decided to purchase another Pump from a second company. Sure enough it worked perfectly. The Pump looked nearly identical to the defective pumps, but there was enough of a difference to tell it was not from the same manufacturer. I let the first company know they probably have a bad batch of Pumps. You might want to try another supplier.
1969 Chevelle, badged SS396, Hugger Orange, 350, 700R4, 10 bolt, column shift with bench seat
Kevin McCaffrey is offline
post #4 of 17 (permalink) Old Nov 12th, 19, 2:56 PM
Mark
Some of the fluid tanks had a filter on the suction tube that could become obstructed over time. If the filter is not restricted, suck fluid from the feed line at the pump to prime the pump. If it still pumps poorly, replace the pump.
modern malibu is offline
post #5 of 17 (permalink) Old Nov 13th, 19, 11:20 AM Thread Starter
Marco
This sounds very similar in nature to what I am dealing with.
Do you remember where you purchased the pump from?
Thanks!
post #6 of 17 (permalink) Old Nov 13th, 19, 12:15 PM
I was having a hard time with mine in my 69 el Camino then I thought about how many times I actually use it, I removed everything and put a flat plate over the wiper motor. It looks so much better without all those hoses and the goofy pump...
hydro462 is offline
post #7 of 17 (permalink) Old Nov 13th, 19, 2:20 PM
Check to make sure you dont have a hole in the line from the tank to the pump. you will suck air out of the tiniest of holes before pulling water up to the pump. i fought with mine for about 3 minutes before i just went to the parts store and bought a universal pump, drilled a hole in the tank and put the feed in it, and just did away with the pump on the wiper motor. Ran the wire for the old pump down to the new one, and the pump actually sits inside the fender, out of view if its kind of an originality thing for you.
I rarely use mine either, but for whatever reason the guy that used to do my PA inspections, really started going by the letter of the book. He actually wouldnt pass my Monte because of non functioning squirters, left turn signal DASH indicator, and high beam indicator. Previously he had told me i would need to get the turn signal cam fixed on my 95 Impala SS, since it wouldnt cancel in one direction. I no longer go to him. The new guy passed my Camaro with no squirters, and, i mean, there is no bottle, hoses, or anything left of it on the car. I'm cool with always making sure the car is safe, but, c'mon, indicator lights?
70montee is offline
post #8 of 17 (permalink) Old Nov 13th, 19, 2:44 PM
I don't think they're allowed to fail you for a non operational "convenience" option,only non-op safety items are reasons for failures .One thing NJ did right is they dropped the inspection procedures for 1995 and below cars.I think they decided there isn't enough of them on the road to worry about them.
71 El Camino SS
406 SBC M21 3.31 12 bolt
71350SS is offline
post #9 of 17 (permalink) Old Nov 13th, 19, 7:31 PM Thread Starter
Marco
I will definitely double check for a hole in the line. All I did was blow down the hole to see if there was a clog.
I tried a universal pump at first, because I felt from the start that it wasn't worth paying $70 for that garbage.
The switch on my Buick is different from what I have seen on the Chevelles. My switch has a push button then a rocker switch, where from videos I have seen Chevelles just have a rocker switch where one side washes the other side operates the wipers.
That push button acts kind of strange, it is more like a on/off kind of thing. Where I press the button then the pump goes at it for a second or two and try to spray fluid. I'm actually trying to sign up to a Buick forum as well to get a more detailed understanding if that is the way the button is supposed to work or if there is something wrong.
So when I press the button to activate the universal pump it will only turn for less than a second, where the mechanical crap seems to run longer.
Does anyone know if these bumps have a reverse polarity issue, like if you put the plug in upside down?
Other wise I will trouble shoot these issues. If nothing comes of it I will assume the pump is defective.
Thanks again guys, all feedback is welcome!
post #10 of 17 (permalink) Old Nov 14th, 19, 7:11 AM
Thanks!
The first two defective pumps were from Ground Up. I alerted them to this fact to hopefully prevent others from experiencing the same issue. The third pump, which worked perfectly, was from YearOne.
post #11 of 17 (permalink) Old Nov 14th, 19, 8:42 AM
Dan, you should consider getting Antique plates. There the best! No inspection, full coverage insurance for a couple hundred bucks, no yearly tags.. I go to a place called AAA to get my titles transformed into antique, they have it done in an hour or so..
hydro462 is offline
post #12 of 17 (permalink) Old Nov 14th, 19, 11:34 AM
You are not the first one to tell me to do that. I get that there really arent any "antique tag" police, but i would break every rule set forth in the antique tag definition. I really dont mind having to get my cars inspected. it puts another set of eyes on it for me, and only ever costs me $35. It just irritated me that my last guy just got picky about the dumbest things, that werent really "safety related" like brakes, ball joints, etc. My insurance isnt really anything to get up tight about either, since im single, insure 3 cars, a golf cart, and 2 quads....you know, you can only drive so many things at once.....
hydro462 likes this.
70montee is offline
post #13 of 17 (permalink) Old Nov 15th, 19, 10:23 AM
Your right about the inspection. People with Antique tags forget "they" are responsible for keeping that car in safe running condition.
Sounds like you had Barney Fife inspect your car...
hydro462 is offline
post #14 of 17 (permalink) Old Nov 15th, 19, 11:34 AM
Greg
Antique plates here mean limited use, the vehicle can only be used to and from parades and shows. I for one want to use my car for other things
Life is too short for caring about every bodies else's stuff
Grock-co is offline
post #15 of 17 (permalink) Old Nov 17th, 19, 9:24 PM Thread Starter
Marco
OK guys,
I looked for holes in the lines to no luck. There is no pressurizing this tank, the lid has a pin hole in it (by design)
I tried to push some water through the lines to get the system started, ran it for a while and it ran like total garbage.
I tried replacing the star with the original pump and that did not work either.
Driving in Georgia I will need to clean my windshield because insects feel that the best way to survive is by hanging out in the middle of busy roads.
I think I want to try and take a shot at replacing it with an electric motor. I tried a cheap universal one and it didn't cut it, any suggestions?
I was also thinking how nice it would be if the feed from the washer tank came out of the bottom of the tank instead of the top. Any suggestions there?
Thanks!
