Headlights went out when I put the high beams on - Chevelle Tech
 5Likes
  • 1 Post By dyno jonn
  • 4 Post By Dean
post #1 of 9 (permalink) Old Oct 29th, 19, 6:59 AM Thread Starter
Robert
Good morning. I drove my 1970 Chevelle SS396 yesterday at night. Naturally, I put the headlights on. When I depressed the high beam switch, all of the headlights went out. Just the headlights. The other lights were all on. Also, after this happened, the interior lights began to flicker. I haven't put a multimeter to it yet. I am guessing that possibly the voltage regulator started to stick and it blew the fuse for the headlights? Any thoughts would be greatly appreciated.
Robert Gross
Groveland FL
Robert Gross
1970 Chevelle SS396
Groveland, FL
robertw144 is offline
post #2 of 9 (permalink) Old Oct 29th, 19, 8:55 AM
Cory
Re: Headlights went out when I put the high beams on
No fuse for the headlights. The headlight switch on the dash utilizes a circuit breaker. You may have a short in the high beam switch or the the high beam wiring circuit.
dream66 is offline
post #3 of 9 (permalink) Old Oct 29th, 19, 9:01 AM
If the low beams returned after hitting the dimmer switch again, here’s the possible problems:
- bad dimmer switch;
- burned out high beam elements;
- break or short in continuity of the wires.
Mencken: “The whole aim of practical politics is to keep the populace alarmed by menacing it with an endless series of hobgoblins, all of them imaginary.”
Alan F is offline
post #4 of 9 (permalink) Old Oct 29th, 19, 9:14 AM
Take the dimmer switch out and spray it down with a electrical contact cleaner, let it dry then spray it down with electrical contact lubrication... Compressed air makes things faster..
hydro462 is offline
post #5 of 9 (permalink) Old Oct 29th, 19, 9:48 AM
Jon N.
What? Nobody believes in test lights any more? Geeez.....
Jon N.
dyno jonn is online now
post #6 of 9 (permalink) Old Oct 29th, 19, 12:13 PM
BTDT Replace the dimmer switch.
post #7 of 9 (permalink) Old Oct 29th, 19, 12:59 PM
First check for voltage and see where you lost it. There is no reason to repair or replace things that aren't broken.
oldcutlass is online now
post #8 of 9 (permalink) Old Oct 29th, 19, 4:13 PM
kevin
mine do that in my 68 el co except its like a delay where they all go out momentarily when I go from high to low. they still work its just a quick black-out.. following this post..
the heckler is online now
post #9 of 9 (permalink) Old Nov 19th, 19, 12:31 AM
Last time I got an inspection, I failed for high beams not working. I just went through alternator hell and just so happen that I touched a loose connection. It was my brights. Find it, clean it, stick it back in. Work wonderfully again.
Jlhook716 is offline
