Normal voltage at full current draw from alternator - Chevelle Tech
 2Likes
  • 2 Post By pnugene
post #1 of 3 (permalink) Old Sep 26th, 19, 8:44 PM Thread Starter
David
Hi,
I swapped my old 10SI alternator for a CS-130 105 amp and installed the smallest pulley (2 3/8'' OD) that I found. At 80% current draw, I was drawing 83 amp when I made the measurement (heater fan, headlights, high beams, electric fan, etc) and at idle I was right on the 13.0 volt. I figured a 105 amp alternator could hold at least a good 14.0 volt until it got to max output. Is this situation normal?
Thx
1968 Chevelle 396 (bored 402) / 4-spd T-10 / 3.73
davlac89 is offline
post #2 of 3 (permalink) Old Sep 26th, 19, 10:38 PM
Randy
Re: Normal voltage at full current draw from alternator
Run the engine speed up to 1500 or so and measure again. You're not gonna maintain 14 volts at idle speed with that much load.
Randy
TC # 5401
67 Project SS Clone
pnugene is offline
post #3 of 3 (permalink) Old Sep 27th, 19, 12:25 PM
Long ago I saw some performance plots for various alternators. Some of the high output ones had the lowest idle outputs.
Thirteen volts at idle still shows that it is charging enough to keep the battery up above the 12.6 nominal voltage. So, no worries.
JWagner is offline
