HEI power and Tach wire - Chevelle Tech
 3Likes
  • 1 Post By Dave Ray
  • 2 Post By hydro462
post #1 of 14 (permalink) Old Sep 14th, 19, 7:31 PM Thread Starter
I have a power wire ran from the fuse box to the HEI and I’m trying to install a tach. Can I connect into this same wire or where do you recommend wiring it?
Tony70Chevelle is offline
post #2 of 14 (permalink) Old Sep 14th, 19, 7:34 PM
Randy
Re: HEI power and Tach wire
HEI distributor has a tach connection next to the power wire. The cap should be marked 'tach'.
Randy
TC # 5401
67 Project SS Clone
pnugene is online now
post #3 of 14 (permalink) Old Sep 14th, 19, 11:01 PM Thread Starter
Yes which is Green. I also have a Red (power). Black (ground) and white (light on the tech). I'm trying to figure out where to run the red power wire.
1970 Chevelle
327/TH350, Bear 13" front, 12" rears, UMI upper/lower A arms, UMI front 1.25 sway bar, UMI rear upper/lower control arms, Ridetech drop spindle, Viking coilovers front/rear, 12 bolt, work in progress
post #4 of 14 (permalink) Old Sep 14th, 19, 11:26 PM
leo
Pictures??
Leo Paugh
Maryland Chevelle Club #017
A.C.E.S.#3731
LeoP is offline
post #5 of 14 (permalink) Old Sep 14th, 19, 11:28 PM
Red goes to ignition I.e. fuse box....
72 SS 402/4 speed/Straub roller and a bunch of Duramaxes.....
jrkrace is offline
post #6 of 14 (permalink) Old Sep 15th, 19, 12:49 AM Thread Starter
Yes I understand that but I already have a 10 gauge wire connected there that powers the HEI. I'm trying to figure out if I can splice into that wire and power the tach or if I need to wire it somewhere else
1970 Chevelle
post #7 of 14 (permalink) Old Sep 15th, 19, 12:58 AM Thread Starter
Originally Posted by LeoP View Post
Pictures??
Bellow is the tach I ordered from amazon and I attached a diagram for the wiring. Being I already have a wire running to the switched 12V for the HEI, I want to know if I can splice into that but I'm afraid of taking voltage away from the distributor
1970 Chevelle
post #8 of 14 (permalink) Old Sep 15th, 19, 10:12 AM
Yes, you can splice into the hei power wire.
oldcutlass is offline
post #9 of 14 (permalink) Old Sep 15th, 19, 1:40 PM
That is correct, both HEI power, and tach power will work just fine piggybacked together on the IGN fuse box terminal. I'd run the tach ground to the engine, and TACH on the cap is the tach signal feed.
LeoP likes this.
Dave Ray is offline
post #10 of 14 (permalink) Old Sep 17th, 19, 1:04 PM Thread Starter
As for the ground your saying to ground it to the engine block?
1970 Chevelle
post #11 of 14 (permalink) Old Sep 17th, 19, 3:23 PM
Any convenient chassis ground will work.
post #12 of 14 (permalink) Old Sep 17th, 19, 4:30 PM
Run the red wire to a switched terminal at the fuse box. The HEI power wire, if its fused at all, would be fused for to high of a load to protect the car from fire if the tack decides to short out...
I would fuse the tach @ 5 amps..
Also do you want the car shutting down if the tach decides to go south on you and blow the circuit.. That HEI has a dedicated circuit for many reasons. I'd leave it alone..
SSJohn and sampoerna415 like this.
hydro462 is offline
post #13 of 14 (permalink) Old Sep 17th, 19, 5:46 PM
The engine is the best ground distribution block you will ever find. Chassis/body is not the first place the ground cable from the battery goes, it is the engine.
Fusing an HEI is not needed. First start up amperes can run well past 5 amperes, so, 5 amp fuse is too low, if fusing is done.
Dave Ray is offline
post #14 of 14 (permalink) Old Sep 17th, 19, 5:54 PM
The HEI in this case does not have a dedicated circuit because the car did not come with one stock. The OP is using the IGN term. in the fuse box which is fused through the adjacent fuse. The tach does not require a fuse as an internal short is usually contained inside the tach. And yes standard failure indication of a bad tach is the car will shutdown and/or refuse to start because it grounds the coil- terminal.
