1964 Chevelle Wiring issue - Chevelle Tech
 2Likes
post #1 of 20 (permalink) Old Sep 2nd, 19, 9:17 AM Thread Starter
Ron
I have a 64 Chevelle that I have restored. I replaced every wiring harness in the car with the exception of the copper flat ribbon cable that connects the rear to the fuse box. I also replaced the turn signal switch. When I completed the job a couple of years back all was well with all lights and blinkers. The car sat in my garage for a couple of years and now I have some strange stuff happening. They are as follows;
1. With the lights off, when I depress the brake pedal not only do the brake lights come on but so does the dash lights as well as the tag lights.
2. With the lights on when I turn on the left blinker the right blinker as well as the tag lights flash.
3. As a side note I lost the function of my horn.
I was thinking the turn signal switch. I have read about grounding problems but not sure where to start. Any help would be much appreciated.
allison1212 is offline
post #2 of 20 (permalink) Old Sep 2nd, 19, 9:44 AM
Allen
Re: 1964 Chevelle Wiring issue
After doing a complete harness in my 64 (original wiring was so hacked up I gave up on patching it) I still had some weird lighting issues, not exactly what you are describing but close. After spending a few hours verifying that I hadn't messed up any of the wiring I tried a new headlight switch and presto, no more issues.
Blown1932 is offline
post #3 of 20 (permalink) Old Sep 2nd, 19, 10:14 AM Thread Starter
Ron
The head light switch had crossed my mind. I think I have an extra one.
Thanks,
Ron
post #4 of 20 (permalink) Old Sep 9th, 19, 9:43 AM Thread Starter
Ron
Headlight switch did not fix the problem.I did have a extra brand new switch. Any other help would be appreciated. Can anyone explain how the wiring is grounded. The first symptom is when I depress the brake the instrument panel light as well as some aftermarket gauges light up without the light switch being on.
post #5 of 20 (permalink) Old Sep 9th, 19, 10:31 AM
The headlight switch has nothing to do with your issue. You have a grounding problem with one of your left side lights. Its back feeding and picking up a ground though the lamps in your regular lighting circuit. The horn is a separate issue between the horn contact in the column and the horn relay or the horn relay to the horns themselves. The horn relay is powered all the time through the stud/s at the bottom looking for a ground from the horn contact. Once engaged it supplies 12v to the horns which are grounded through the chassis.
oldcutlass is offline
post #6 of 20 (permalink) Old Sep 9th, 19, 10:44 AM Thread Starter
Ron
The horn is working. How do you suggest I start to find the problem? Thanks for any help.
Thanks,
Ron
post #7 of 20 (permalink) Old Sep 9th, 19, 10:46 AM
Ron, check the ground on your lights, as Eric said. You should find one "open" and not grounding. Dont even need a multitester , a circuit checker is all.
post #8 of 20 (permalink) Old Sep 9th, 19, 11:17 AM Thread Starter
Ron
Check it from the bulb housing to the car body?
Ron
post #9 of 20 (permalink) Old Sep 10th, 19, 11:45 AM
Thereís a rubber gasket between the tail light housing and the body. This means the circuit is depending on the mounting screws to complete the circuit. 55-year old mounting screws may not be up for that task. At least try using new mounting screws.
Hereís another suggestion. I just re-wired my entire í65 El Camino with an American Autowire kit. In spite of that, I still drilled a hole in the back of the rear tail light housings for a screw, and ran a wire from that screw to a frame mounted ground bar. Okay, so maybe thatís a bit of overkill. But Iím not worried about grounds at the rear of a 54-year old Elco. I also used the ground bar for the gas gauge circuit and the gas tank.
Hope this helps. Below is what I found behind the driver's side tail light. You might consider checking there too.
Name:	Old Harness 3.jpg
wihaltom likes this.
rmc65elco is offline
post #10 of 20 (permalink) Old Sep 10th, 19, 1:36 PM Thread Starter
Ron
I will give it a try! So you think its definitely in the trunk area where the problem exists? It all started with the left rear blinker not working and has progressed to this. Keep in mind I replaced all wiring harness with the exception of the flat black cable that you show in the picture. Ill keep you posted and thanks.
Ron
post #11 of 20 (permalink) Old Sep 10th, 19, 4:33 PM
Ron
You have to start the process looking some where...
post #12 of 20 (permalink) Old Sep 11th, 19, 7:32 AM Thread Starter
Ron
That is where I have focused, but still no resolution.
post #13 of 20 (permalink) Old Sep 11th, 19, 7:56 AM
Could be possible you have a filament jumping the brake/turn circuit to the parking light circuit.
You said the left blinker is causing problems. Pull the front left blinker bulb, test. Pull the left rear blinker bulb, test. I'm hoping it's one of those bulbs.
*Jeff*
LQ4 / T56 Swap
Hotwire is offline
post #14 of 20 (permalink) Old Sep 12th, 19, 3:16 PM Thread Starter
Ron
What is the best method to check the ground? I have a meter and a circuit tester light. I'm more interested in what points I should use to check it? How would you go about adding a ground?
Thanks,
Ron
post #15 of 20 (permalink) Old Sep 14th, 19, 3:37 PM
"Hotwire" makes an interesting point. Remove the bulbs from the parking light and tail light housings. Use your test meter to check for continuity between the barrel of the light bulbs and each of the two contacts on the bottom of the bulb. These should individually show continuity. Next, check for continuity between the two contacts on the bottom of each bulb. In this case, continuity is a bad thing and means the filaments are shorted. Look at the filaments to see. Either way, I'd replace the bulbs. Hope this helps.
Name:	06 - Parking Light Bulb.jpg
