71 Chevelle sweepdash fuel gauge reads full (Troubleshooted) - Chevelle Tech
  • 1 Post By HKalin
post #1 of 6 (permalink) Old Aug 7th, 19, 6:15 PM Thread Starter
Murph
My 71 Chevelle (Sweep dash) has a new tank and sending unit. The gauge on the dash reads passed full. I've read probably 15-20 posts and websites about fuel gauge troubleshooting and honestly I think I'm overwhelmed/confused from the various things I've read.
I have not dropped the tank yet and dealt with the sender directly.
Here is breakdown of the testing:
  1. Unplugged connector/rubber boot at license plate: Grounded tan wire -- Gas gauge goes to Empty
  2. Grounded tan wire at harmonica connector -- Gas gauge goes to Empty
  3. Grounded tan wire at gauge -- Gas gauge goes to Empty
  4. I also checked the ohms coming through the tan wire at all 3 locations and at all 3 it read 50-52ohms. (Trunk, Harmonica, Gauge)
  5. Replaced the ground at the gauge with a good known ground. When unplugged it went to empty, when the ground was plugged in it goes back to full.
  6. Replaced the ground from the sending unit to the frame under the car with a good known ground. No change in fuel gauge.
So here is where I get confused. I then bought an aftermarket fuel gauge and hooked it up inside the trunk. I ran jumpers from the Tan sender wire, power, and a good ground. With no ground plugged in, the aftermarket gauge reads past FULL. With the ground, it reads empty. Ohms check showed 50-52.
I've read that a full reading means a bad ground or an open TAN wire. I figured if I wired up an aftermarket gauge and it worked in the trunk I could then move forward to the harmonica connector, and if it worked there, passed that to the dash.
I think the sending unit is faulty or grounding itself out somewhere, which will require me to drop the tank. Any help would be appreciated! Thanks.
I hate rattle-canned brake boosters.
Cancel is offline
post #2 of 6 (permalink) Old Aug 7th, 19, 6:31 PM
Re: 71 Chevelle sweepdash fuel gauge reads full (Troubleshooted)
This is confusing. The connected ground should operate the gauge. Very unlikely, but is the sending unit installed backwards inside the tank?
It's a pretty common problem on these cars that the sending unit is usually the culprit when the gauge is pegged on Full.
64 2 door Wagon Build thread
67 2 door Sedan LS1 T56
Pete 67 is offline
post #3 of 6 (permalink) Old Aug 8th, 19, 7:01 AM
Hank
Did you put the new tank and sender in. Could you have pinched the tan wire between the tank and the trunk floor. If you drop the tank out pull the sender and keep it hooked up. Move the float level rod to see how the gauge reads. You can move it in quarters, empty, 1/4, 1/2, 3/4, and full. See how the different positions correspond with the gauge.
Pete 67 likes this.
HKalin is online now
post #4 of 6 (permalink) Old Aug 11th, 19, 1:20 PM Thread Starter
Murph
Just a little update: been driving a good amount letting the fuel run down. The gauges needle has begun to bounce around while driving. When I'm parked, as of right now the gauge reads 1/4 tank. I checked the ohms and I'm reading ~30amps.
Waiting to run the gas down before I drop the tank. But I suspect/agree that it is the sending unit. Maybe it's pinched? I did not put it in
Cancel is offline
post #5 of 6 (permalink) Old Aug 13th, 19, 1:14 PM Thread Starter
Murph
Managed to drop the tank and test the sending unit. Here's where it's at:
Sending unit ohms arent steady/consistent. Jumps around wildly.
Hooked old gauge up to new sending unit, didn't read properly.
Hooked old sending unit up to new gauge, didn't read properly.
Hooked new sending unit up to new gauge, read properly.
So at this point I think both the gauge and sending unit are both junk. I can't find any sweep dash fuel gauges (ha ha) to replace it so I'm gonna run an aftermarket gauge under my dash. I would like to replace my dash with an SS dash in the future anyway. Thanks for all the help!
Cancel is offline
post #6 of 6 (permalink) Old Aug 13th, 19, 7:40 PM
Jonathan
Ask around, I bet some one here has a sweep dash gauge.
Two 72 Chevelle Malibus, both 350 2bbls one Placer Gold, one Midnight Bronze
Other cars:
2005 Pontiac Vibe
2005 Ford Excursion
2000 Dodge Durango
2003 Mercedes E320
2-2018 Ford Fusions
2013 Ford Fusion
Chevelle_Nut is offline
