First time doing a wiring job need help - '70 - Chevelle Tech
 5Likes
  • 2 Post By rmc65elco
  • 2 Post By Slick87gn
  • 1 Post By busterwivell
post #1 of 8 (permalink) Old Jul 8th, 19, 8:18 PM Thread Starter
I need to know which set of jaws to use on the tool aid crimper and how to do the crimps currently I知 working with a AAW classic update kit for my 1970 and I知 working on the instrument cluster wiring and it痴 a bit difficult since I致e never done this before. I知 trying to take pics to make it easier for you guys to help. Thanks in advance
1970Chevelle__ is offline
post #2 of 8 (permalink) Old Jul 8th, 19, 8:55 PM
Re: First time doing a wiring job need help
Looks like you are best off using the middle set of jaws (18922) in the photo above. They will fold the tabs on the connector back in on the wire.
Also, check out this video at American Autowire:
https://www.americanautowire.com/pro...rimping-tools/
I'm currently using their Classic Update harness and a set of their crimpers to rewire my '65 El Camino.
Good Luck!
busterwivell and David Bates like this.
rmc65elco is offline
post #3 of 8 (permalink) Old Jul 9th, 19, 7:37 AM
Re: First time doing a wiring job need help - '70
i used that same tool when I wired my '70 El Camino. Watch the videos and they give you enough test connectors. Once you start it'll be easy. Don't cut your wires too short. Always leave some slack for later repairs. Good Luck.
Slick87gn is offline
post #4 of 8 (permalink) Old Jul 9th, 19, 9:05 AM
Good advice here.......watch that video
David Bates likes this.
66 Malibu
busterwivell is offline
post #5 of 8 (permalink) Old Jul 9th, 19, 9:58 AM
^^^ Excellent advice from all.
USAF Retired (1968-1988)
David Bates is offline
post #6 of 8 (permalink) Old Jul 9th, 19, 10:56 AM Thread Starter
You used the tool aid tool? The problem I知 having it that the jaws are wider than the tool in the video as in it catches both sets of tabs on the connectors when I need just one at a time
post #7 of 8 (permalink) Old Jul 9th, 19, 11:51 AM
Cody
The tool should have stepped teeth, so it will crimp on the wire and the insulation at the same time. Something like this:
Blackhawk is offline
post #8 of 8 (permalink) Old Jul 9th, 19, 12:00 PM
that tool should be stepped. Check it out.
This Thread is more than 372 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
