Engine bay bulk head sealant? - Chevelle Tech
  • 1 Post By Ark68SS
post #1 of 7 (permalink) Old Jun 10th, 19, 10:04 AM Thread Starter
Just got done cleaning out the factory goo on the engine bay bulkhead where I needed to add tach and amp meter connections. What do you use to water proof seal the area when done?
72soft-top is offline
post #2 of 7 (permalink) Old Jun 10th, 19, 10:50 PM Thread Starter
Hmmm. This says silicone sealant.
https://www.americanautowire.com/PDF...20IN%202.0.pdf
post #3 of 7 (permalink) Old Jun 10th, 19, 10:58 PM
Terry
Re: Engine bay bulk head sealant?
I would use Di-electric grease. Terry
68-13427 is offline
post #4 of 7 (permalink) Old Jun 11th, 19, 12:23 AM
Levon
Sealant on the exterior and dielectic on the mating section inside.
Levon Hovagimian
Team Chevelle #279
1966 427 Corvette SOLD
Priddis, Ab. Canada
LevonH is offline
post #5 of 7 (permalink) Old Jun 11th, 19, 2:43 PM
The factory "grease" was there to do two things, deter the formation of corrosion in the contacts, and stop moisture from getting to them in the first place. It was never intended to help electrical transfer in the terminals. Problem is, after decades of heat, cold, chemical attack, pressure washing, adverse conditions, it gets worn out, and needs to be replaced. It was never meant to last 50 years, only about 20 or so. I have never seen a bulkhead connector to fuse box sealed off with silicone seal, fuse box to firewall, a few.
Dave Ray is offline
post #6 of 7 (permalink) Old Jun 18th, 19, 12:55 AM
Sam
I just went through this on my car. I removed and added wires at the bulkhead. I used 3m black weather stripe adhesive around the wires. It flows well and self levels.
snake2k is offline
post #7 of 7 (permalink) Old Jun 18th, 19, 5:37 PM
Steamy
Wink Re: Engine bay bulk head sealant?
Black 3M Strip Caulk. Don't use silicone, it will cause terminal corrosion.
BillL
69SS454 likes this.
My Showroom
Ark68SS is offline
