Wiring harness direct fit plug and play considering major upgrades in - Page 2 - Chevelle Tech
 5Likes
post #16 of 33 (permalink) Old May 23rd, 19, 7:23 PM
Terry
Re: Wiring harness direct fit plug and play considering major upgrades
70, AAW harnesses come with the wires, the plug ends and fuse block for the dash harness. It does not come with any switches, flashers, dimmer switch, or horn relay, have to buy them separate. Terry
68-13427 is offline
post #17 of 33 (permalink) Old May 23rd, 19, 9:20 PM
blm
The AAW classic update kit comes with all that stuff. At least it did when I bought one for my 69.
blm is offline
post #18 of 33 (permalink) Old May 23rd, 19, 9:40 PM Thread Starter
Really? The website says it does maybe theyíve switched it up?
1970Chevelle__ is offline
post #19 of 33 (permalink) Old May 23rd, 19, 9:41 PM Thread Starter
Well on the website it says it does but now Iím not really sure and I still canít compare it to what comes with painless performance as many people seem to just opt for AAW
post #20 of 33 (permalink) Old May 23rd, 19, 10:12 PM
Greg.
According to this most of the stuff is included
https://www.americanautowire.com/sho...70-72-chevelle
Check the " Description" Tab
Check the " Instructions " Tab
- Warning & Contents Sheet
510105 - Classic Update Series Kit
1970-72 Chevrolet Chevelle
This kit contains the following components:
Part
Bag Number Description Quantity
500042 Floor Dimmer Switch 1
500332 Headlight Switch 1
500707 Fuse, Relay, and Flasher kit 1
N 500708 Courtesy Light kit 1
500919 Practice Terminal Crimping Set 1
G 510107 Dash Harness kit 1 ( includes; Horn Relay )
J 510108 Engine Wiring Kit 1
L 510109 Front Light Wiring kit 1
H 510110 Instrument Cluster wiring kit 1
M 510111 Rear Body Wiring kit 1
K 510112 Console Wiring kit 1
92969162 Kit Introduction Instruction Sheet 1
92970010 Warning Sheet 1
- Instruction Sheet for 510105 Wiring Kit 70-72 Chevelle Classic Update Series
shows that the following are accessories (assuming you need to buy in addition to)
- OEM style turn signal switch p/n 01997938 (1970-72)
- 1970-72 OEM style wiper switches p/n 01993464 - without recessed park
p/n 01993465 - with recessed park
- Muncie 4 speed back up lamp switch p/n 03943657 (1970-72)
67 Chevelle Malibu SS Cdn
Born 283 / PG / A51
60' = 1.664
1/8 = 7.532 et / 91 mph
1/4 = 11.814 et / 115 mph
60' = 1.561
1/8 = 7.411 et / 90.18 mph
1/4 = ??.??? et / ??? mph
Kirk's67SS is offline
post #21 of 33 (permalink) Old May 24th, 19, 12:16 AM
I used a painless direct fit in a mid 60's Chevy truck about 15 years ago. I was not impressed with it. The terminals and connectors were the cheap solderless style found at a parts store. It also lacked a connector at the firewall for the hood mounted turn signal / parking lights, making the difficult to remove unless the wiring was fished out of the hood. I haven't used one since then so I can't speak for the quality of the current product.
dell72 is offline
post #22 of 33 (permalink) Old May 24th, 19, 7:08 AM
blm
I am assuming what Terry means by this.statement is if one buys an individual harness it does not come with the above items. As it shouldnt. However if one buys the Classic Update Kit is does come with all the things mentioned.
blm is offline
post #23 of 33 (permalink) Old May 24th, 19, 9:11 AM
I bought the AAW classic update and it came with fuses, relays, flashers and new switches for headlights and dimmer. I think different car feature different items. A friend bought a kit for a 65 Chevelle and his included the above items plus an ignition switch.
dell72 is offline
post #24 of 33 (permalink) Old May 24th, 19, 7:39 PM Thread Starter
Is the harness long enough that you can route it in a different way than factory like if I wanted to run the headlight harness under the driver fender? Or anyone of the other ways to clean up the engine bay and make it look like thereís a minimum amount of wiring?
post #25 of 33 (permalink) Old May 24th, 19, 8:19 PM
Terry
Guy's, I should have been more specific about my comment. I purchased my harnesses in stages, not all at once. I did not buy the classic update kit, sorry for the confusion. Terry
68-13427 is offline
post #26 of 33 (permalink) Old May 24th, 19, 8:20 PM
blm
I seem to recall cutting a few feet off the end of most wires. Definitely have a bunch of wire left over. I assume you mean running the wires between the fender and inner fender. If so that is how I did mine.
blm is offline
post #27 of 33 (permalink) Old May 24th, 19, 9:15 PM Thread Starter
Yeah thatís what I meant. Do you have any tips and how to route the wiring so that the engine bay is basically super clean and now wires showing
post #28 of 33 (permalink) Old May 24th, 19, 9:24 PM
blm
Use harness tape ( not electrical tape) so what wires that are showing look good.
blm is offline
post #29 of 33 (permalink) Old May 24th, 19, 11:42 PM Thread Starter
Thanks! Do you have a lot of wires showing or did the kit get it so you could hide a lot of them?
post #30 of 33 (permalink) Old May 25th, 19, 7:13 AM
blm
Well no matter what you do there will be a few wires exposed. Such as wire to an electric choke, wires to the alternator, wire to water temp sensor. But I was able to acquire some wire sheath that also acts as a protector against heat. Got it from one of the vendors and it is only about 3/16 diameter. Can get two wires or so inside the sheath. At least it keeps anything exposed the same color.
One thing that cleans up the engine bay is the looms for the plug wires that run along the base of the valve covers.
blm is offline
Chevrolet Chevelle Backup LEDs! Plug & Play Install! Added Safety! Diode Dynamics Diode Dynamics 4 Nov 25th, 16 2:14 PM
LED Plug and Play 1971 Chevelle dbprecision Electrical & Wiring 17 Dec 4th, 15 9:34 PM
1967 Chevelle Under Dash Wiring Harness JROCK142 Electrical & Wiring 1 Oct 28th, 15 7:03 AM
Plug and play wiring harness urclever Electrical & Wiring 13 Dec 24th, 13 7:44 PM
Wiring Harness for 68' GatorsUF Electrical & Wiring 8 Sep 15th, 13 12:18 PM
