Total Electrical Loss - Chevelle Tech
 18Likes
post #1 of 27 (permalink) Old Apr 17th, 19, 2:09 PM Thread Starter
Hi All. So a week ago, while driving home late at night - I experienced my first ever total electrical loss on my '69. I unfortunately had to have it towed home. Had power at battery (used jumpers to confirm) and that was it. Long story short - I found a green wire (1 of 2) in my bright beam lamp had came out of the blade connection. I read on this forum about turning on wipers while checking for shorts, etc. So I did that. Low and behold - when I rewired the blade connector with both feeds into it - the wipers went into motion, my interior lights came on - and she fired right up. How is that even possible? I'm afraid to leave the garage.
Drogjr66 is offline
post #2 of 27 (permalink) Old Apr 17th, 19, 3:02 PM
Re: Total Electrical Loss
And here I thought you for sure blew the fusible link. Well, a quick check of the wiring schematics will show you how. Its a weird setup. Hopefully an expert will chime in. Until then, hope you arent colorblind!
https://www.chevellestuff.net/1969/misc/wiring.htm
Dean and Bow_Tied like this.
post #3 of 27 (permalink) Old Apr 17th, 19, 3:11 PM
That makes no sense what so ever. Totally un related to your issue. I would check the bulkhead connectors. In case you ever get stranded again, run a jumper from the battery + to your coil + terminal and jumper the starter solenoid. You should be able to drive the car home.
oldcutlass is online now
post #4 of 27 (permalink) Old Apr 17th, 19, 3:20 PM
I had this happen on my 68 once, it was intermittent. Eventually found that my ignition switch was bad.
Agree with others, check bulkhead connections, and ignition switch.
Scott W.
Electrical Engineer
700R4
This is how we roll:
red68chevL is offline
post #5 of 27 (permalink) Old Apr 17th, 19, 3:21 PM
I have posted before, I had a 1975 Impala that was hit on the side of the front bumper, and after that, every now and then, everything electrical would fail except the engine would keep running. (maybe horn would work too?) And if I popped the hood to check, everything would work just by pulling the hood release, without even opening it. I can only assume it was a ground strap loose.
Pioneer4x4 is offline
post #6 of 27 (permalink) Old Apr 17th, 19, 5:31 PM
I agree.
I would be double checking the fusible link that goes from the positive battery cable to the terminal on the core support, then to the BAT terminal of the horn relay.
post #7 of 27 (permalink) Old Apr 17th, 19, 7:27 PM
The battery cable may be rotted and corroded inside the terminal. It's often not seen.
68-13427 likes this.
LS1tech.com supermoderator.
How may I help you?
1999 Trans Am-500hp
paul bell is online now
post #8 of 27 (permalink) Old Apr 17th, 19, 8:32 PM
I my 70 driver glovebox I keep an old screwdriver, And a 3 foot piece of wire with Gator clips on both ends, This is my " Get home kit "............,, I was gonna say Roach clips.
Roach Clips, Well, Thats another Time & Place !
Robinls5 is online now
post #9 of 27 (permalink) Old Apr 17th, 19, 11:23 PM
Frank
Can you clarify the description "green wire (1 of 2) in my bright beam lamp had came out of the blade connection"? Was the loose connection at the headlamp (Light Green and two black wires), at the firewall connector, in the dash, or on the headlight switch?
-Frank
1970 Chevelle Malibu, one family owner
355 SBC, XE262H cam, Performer RPM heads, MSD HEI, TH200-4R trans, 3.55:1 Posi, digital gauges
Malibu70 is offline
post #10 of 27 (permalink) Old Apr 18th, 19, 9:24 AM
For those younger owners you may want to describe how you use them. (As intended to get home, not as "holders")
I get it, and have used Jumper Cables for that purpose.
post #11 of 27 (permalink) Old Apr 19th, 19, 1:22 AM
I'd like some clarification. Is the wire supposed to go from the positive terminal on the battery to the "BATT" on the distributor? Does the flat blade screwdriver play a role, or is it just generally a good tool to "get home"?
658Chevy is offline
post #12 of 27 (permalink) Old Apr 19th, 19, 6:00 AM
Basically use the wire to bypass the ignition switch, and the screwdriver to short the starter terminals to get it to crank over.
Drogjr66 likes this.
post #13 of 27 (permalink) Old Apr 19th, 19, 6:20 AM
Yes, that is the coil+ terminal of an HEI distributor.
post #14 of 27 (permalink) Old Apr 19th, 19, 9:25 AM
Thanks, guys. That makes sense.
658Chevy is offline
post #15 of 27 (permalink) Old Apr 19th, 19, 9:59 AM Thread Starter
Thanks. I pulled both and made sure they're clean and in good shape.
paul bell likes this.
Drogjr66 is offline
396 Poor Off Idle Torque Reelysalty Performance 127 Feb 9th, 19 7:29 PM
Total loss of electrical power while driving. jonathanch Electrical & Wiring 4 Jun 10th, 18 5:26 AM
Crushed fender = Total Loss??? tx_an Chevelle Tech 40 Feb 28th, 16 12:09 PM
Total power loss proj4ever Chevelle Tech 7 Apr 23rd, 13 6:32 PM
Both '65 Malibu's total loss in flood MalibuSeaS Chevelle Tech 59 Jan 18th, 13 1:07 PM
