Total Electrical Loss - Page 2 - Chevelle Tech
 18Likes
post #16 of 27 (permalink) Old Apr 19th, 19, 10:03 AM Thread Starter
Re: Total Electrical Loss
Originally Posted by Malibu70 View Post
Can you clarify the description "green wire (1 of 2) in my bright beam lamp had came out of the blade connection"? Was the loose connection at the headlamp (Light Green and two black wires), at the firewall connector, in the dash, or on the headlight switch?
One of the green wires was out of the blade. I pulled apart and reinserted the green wire and now everything works. Maybe it's a coincidence? Sorry - it was at the lamp.
Drogjr66 is offline
post #17 of 27 (permalink) Old Apr 19th, 19, 11:25 AM
Fat Stig
Originally Posted by Drogjr66 View Post
Hi All. So a week ago, while driving home late at night - I experienced my first ever total electrical loss on my '69. I unfortunately had to have it towed home. Had power at battery (used jumpers to confirm) and that was it. Long story short - I found a green wire (1 of 2) in my bright beam lamp had came out of the blade connection. I read on this forum about turning on wipers while checking for shorts, etc. So I did that. Low and behold - when I rewired the blade connector with both feeds into it - the wipers went into motion, my interior lights came on - and she fired right up. How is that even possible? I'm afraid to leave the garage.
Electrical stuff is weird. I was ready to throw in the towel on my CRX autocross car last week. I had spark but no fuel, the main relay (with one circuit dedicated to the fuel pump) was bad, so I replaced it. 12v to the proper terminals on the relay closed it, and I had 12v with the key on to the requisite spades on the connector. Jumping the connector terminals ran the fuel pump, yet with the two connected, the pump wouldn't run with the key in the on position. WTH?? Turns out it was a bad ground on the engine block.
Originally Posted by jpete, Dean, Derek69SS, hoffbug, rubadub, Grandsport, Thomas Jefferson, 1badss396, MEJ1990TM, and mrdjc99
As usual, Andy is right
If it doesn't fit, force it. If it breaks, it needed to be replaced anyway.
I have to keep reminding myself this isn't a Z16 convertible, Evening Orchid Camaro, or factory 1966 SS427 and get on with it.
Andy69 is online now
post #18 of 27 (permalink) Old Apr 24th, 19, 12:56 PM Thread Starter
So everything worked well on Sunday as I took the car for a nice 50 mile ride around. Then Monday, problem reoccurred. This time, the tach started jumping erratically then I lost all power again. Got the car home, disconnected the battery overnight. Connected Monday morning, tested all interior lights, brakes, headlights, etc. Everything worked. Turned the key - lost all power. Disconnected the battery, reconnected, repeat and same thing. I did notice once that with the car in Neutral - wiggling the shifter caused some jumping of the voltmeter? Maybe unrelated? Maybe I was seeing things. I've read that the ignition switch may be on the column? Or the clutch pedal? Any thoughts?
Drogjr66 is offline
post #19 of 27 (permalink) Old Apr 24th, 19, 1:13 PM
You never told us the year of your car but looking at the battery post clamp, wrap on the headlight harness and your name, it looks like you have a 66.
I suggest you swap the ignition switch. These things don't last forever, if it's original, it's 53 years old.
LS1tech.com supermoderator.
How may I help you?
1999 Trans Am-500hp
paul bell is offline
post #20 of 27 (permalink) Old Apr 24th, 19, 1:42 PM Thread Starter
It's a 1969. Rewired completely approximately 4 years ago with an American Wiring kit. I'm not sure if they replaced that or not. Will check into this weekend.
Drogjr66 is offline
post #21 of 27 (permalink) Old Apr 24th, 19, 1:47 PM
Ah. Sorry, the ignition switch is more difficult to replace.
When you re-wired, did you replace the switch with new?
How may I help you?
1999 Trans Am-500hp
post #22 of 27 (permalink) Old Apr 24th, 19, 2:03 PM
Louis
I the exact same thing in my 69 Chevelle. It turn out the main feed ( Red wire ) going to the blade connector started to overheat in the bulkhead connector. It got loose and oxidized from the heat it produced. Got so hot it was melting the plastic around the blade connector.
Louis
Original owner
lg1969 is offline
post #23 of 27 (permalink) Old Apr 24th, 19, 2:12 PM Thread Starter
Wiring was completed prior to my purchase by previous owner. I'm not sure? If the key/tumbler/lock is the same as the "switch" and all one-piece - I doubt it was replaced. I was into the steering column earlier this year to replace the blinker return cam, etc. Everything looked pretty old in the column.
Drogjr66 is offline
post #24 of 27 (permalink) Old Apr 24th, 19, 2:13 PM Thread Starter
I'll give this a look too! Thanks for the idea.
Drogjr66 is offline
post #25 of 27 (permalink) Old Apr 24th, 19, 2:32 PM
The actual switch is at the base of the steering column (interior). Other than the key buzzer, there is nothing electrical in the key switch itself, but it's connected via a rod that runs down the column to the switch. It's possible the issue could be with the switch, it's not expensive to replace if it wasn't done as part of the rewiring.
jim
paul bell and Drogjr66 like this.
Jim's69Ragtop is offline
post #26 of 27 (permalink) Old Apr 24th, 19, 4:28 PM
Before you start throwing parts at it lets try troubleshooting. The headlights do not go through the ignition switch, so of you lost all power its not the switch. Again check the main feed wire through the bulkhead connector.
paul bell likes this.
oldcutlass is online now
post #27 of 27 (permalink) Old Apr 26th, 19, 8:53 AM Thread Starter
Thanks to all of you - this forum has been incredibly helpful at all levels! Ran a jumper directly to fuse block from battery - car started, everything worked. So I disconnected the jumper and applied my test light to the fuse block feed, had my daughter watch the light and began shaking/chasing wires. Found the culprit in a bird's nest of wires taped and zip tied next to the starter. The hot wire was only in the blade connector with 2-3 strands of copper. Thanks again for all of your help fellas!
Drogjr66 is offline
This Thread is more than 396 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
396 Poor Off Idle Torque Reelysalty Performance 127 Feb 9th, 19 7:29 PM
Total loss of electrical power while driving. jonathanch Electrical & Wiring 4 Jun 10th, 18 5:26 AM
Crushed fender = Total Loss??? tx_an Chevelle Tech 40 Feb 28th, 16 12:09 PM
Total power loss proj4ever Chevelle Tech 7 Apr 23rd, 13 6:32 PM
Both '65 Malibu's total loss in flood MalibuSeaS Chevelle Tech 59 Jan 18th, 13 1:07 PM
