67 SS brake switch & dash lighting - Chevelle Tech
post #1 of 4 (permalink) Old Apr 14th, 19, 12:01 PM Thread Starter
Couple of questions. My Chevelle has been restored so I donít know if Iím dealing with original equipment. Been having trouble with my brake/stop light switch. It fits into a hole in the bracket above the pedal but even when adjusted fully into the bracket it still doesnít reach the plate to depress the plunger. So my brake lights stay on. Didnít see any other way to adjust it or the bracket. The car has power front disc and when searching vendors for a new switch OPGI was the only vendor that showed a switch for power brakes. Couldnít see a difference but suspect that maybe the plunger travel distance is different?
My other question is how many light bulbs light up the dash and their general location. I would like to replace them with disable led bulbs if I can find them.
Any help would be appreciated.
Jack
Jockopres is offline
post #2 of 4 (permalink) Old Apr 14th, 19, 12:25 PM
Troy
Re: 67 SS brake switch & dash lighting
Does your brake pedal have a return spring and does it return to the rubber stopper? If so, you might not have the correct switch. However, the same switch was used on many different applications and is a very standard item. The local auto parts store should have one.
As for using LED's in the dash lights, the factory dimmer switch is incapable of dimming LED's. You would have to add a LED compatible dimmer or make sure you don't put to bright of an LED and live with it.
66 CHEVELLE
senna is offline
post #3 of 4 (permalink) Old Apr 14th, 19, 12:26 PM
Hank
At the pedal there is a clevis that is connected to a rod coming out of the back of the booster. You should be able to adjust the pedal there to bring it up higher to trigger the switch. Also if you have power brakes there should be no return spring for the pedal the power booster is what returns the pedal and it dosen't have to come up to the rubber bumper either.
HKalin is offline
post #4 of 4 (permalink) Old Apr 14th, 19, 7:43 PM Thread Starter
Thanks. Appreciate the info.
This Thread is more than 413 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
Parking brake switch Dyna=Lowrider Electrical & Wiring 9 Aug 25th, 18 5:12 PM
How to repair a notched Parking Brake Switch nylon/teflon pad MarkP Restoration Corner 3 Jun 28th, 15 12:17 PM
Last Issue: dash brake light is always up forever young Electrical & Wiring 4 Aug 12th, 14 7:44 PM
Performance Brake Kits at CARiD - Your Safety Guarantee! Carid CARiD.com 1 Mar 20th, 13 7:03 AM
Parking brake light switch sevendchevy Chevelle Tech 6 Mar 9th, 13 11:10 AM
