Horn wiring - Chevelle Tech
post #1 of 4 (permalink) Old Apr 3rd, 19, 1:30 PM Thread Starter
Michael
Send a message via AIM to 69Chev427
Horn wiring
I purchased a complete new steering wheel kit for my 69 and I'm trying to figure out where to connect the 2 horn button wires. Any help or pictures would be appreciated. Thanks!
Michael Hoover
1969 Chevelle 427 BBC
[email protected]
69Chev427 is offline
post #2 of 4 (permalink) Old Apr 3rd, 19, 1:47 PM
Re: Horn wiring
On my 70 El Camino, those wires connect to the horn button assembly under each horn button. If you ground those wires, the horn will make horn noises. Pushing either horn button (if equipped with two) is the same as grounding those wires.
There should be a connector near the turn signal switch area to connect the other end.
Sent from my SAMSUNG-SM-N900A using Tapatalk
B52bombardier1 is offline
post #3 of 4 (permalink) Old Apr 3rd, 19, 3:48 PM
Re: Horn wiring
Please post a picture showing the ends of your wires. Then I can help you. Do you have a small brass cup crimped on the end with a compression retainer to hold the wires into the tube on the cancelling cam?
RealRed70 is offline
post #4 of 4 (permalink) Old Apr 3rd, 19, 3:52 PM
Re: Horn wiring
Check out post 12 and 14 in the link below. This will help you.
https://www.chevelles.com/forums/27-...something.html
1966 Chevelle Horn relay wiring..HELP ! Clintsblue66 Electrical & Wiring 12 Dec 18th, 16 9:00 PM
Horn Relay Back Feed ? Wiring aggravation. Outlaw23 Electrical & Wiring 3 May 13th, 15 7:30 AM
Horn relay wiring hookup for '64 chevelle malibu 1964MalibuSS Electrical & Wiring 2 Jun 18th, 13 7:03 PM
'64 HORN RELAY Wiring HOOKUP (Help Needed) 1964MalibuSS Electrical & Wiring 0 Jun 11th, 13 4:48 PM
Upgrade horn relay and wiring? High amp alternator 376Shovel Electrical & Wiring 7 Jun 11th, 13 4:05 PM
