Harness to the starter solenoid - Chevelle Tech
 5Likes
  • 2 Post By gnicholson
  • 2 Post By Philip
  • 1 Post By 1943MB
post #1 of 5 (permalink) Old Apr 2nd, 19, 8:53 PM Thread Starter
Lou
Hi,
When I wired up my starter solenoid of my 65 Chevelle I attached a wire to the "S" terminal of the solenoid and the larger cable to the positive terminal.
The "S" was the terminal when connected to the positive side of the battery turned the starter over.
I'm looking at my original wiring harness and cross checking wiring diagrams to see which of the two connectors go to the "S" terminal and the "R" terminal.
Does anyone know what the R and S mean and which wire goes where from my harness ? On every diagram I can find I'm seeing the two wires , one noted as red and the other black and pink going to the two terminals but in all cases they do not say which terminal on the solenoid is "R" and which is "S". The Assembly instructions show the "R and the "S" terminals but they don't say what color the wires are and to make things even more confusing they show three wires and the starter cable all converging on the solenoid in a side view with no reference to terminals or wiring colors.
Can anyone help
Thanks,
Lou
1943MB is offline
post #2 of 5 (permalink) Old Apr 2nd, 19, 9:49 PM
Gary
Re: Harness to the starter solenoid
the s or switch ,starter terminal is usually purple . it completes the circuit from the ign switch to pull the sol in to start the car. the r or resister terminal goes to the pos terminal of the coil and is for 73 and older cars with point ignition. it gives full batt voltage to the coil during cranking
David Bates and 1943MB like this.
gnicholson is offline
post #3 of 5 (permalink) Old Apr 2nd, 19, 10:32 PM Thread Starter
Lou
Okay, great got it , thanks a million
Lou
1943MB is offline
post #4 of 5 (permalink) Old Apr 3rd, 19, 1:32 AM
The R terminal wire is usually yellow and on a lot of the older cars is needed to have the ignition powered up during cranking.
LeoP and 1943MB like this.
63 Nova wagon
Philip is offline
post #5 of 5 (permalink) Old Apr 3rd, 19, 10:23 AM Thread Starter
Lou
I had an idea, since I was looking at wires from my harness that were different colors than you guys and the books or charts or diagrams described I decided to run a continuity test.
Took the coil wire and put it to the positive terminal of my battery and ran my light continuity tester between the two wires in question and found the right wire by elimination. The coil wire is the black with a small narrow yellow lines wire which would go to the "R" terminal.
Thanks for the help
Lou
LeoP likes this.
1943MB is offline
Starter Solenoid Issue archelo69 Electrical & Wiring 9 Nov 18th, 16 7:35 PM
Starter Solenoid Story - Check your grouding surfaces. Lew540 Electrical & Wiring 1 Jul 14th, 16 10:31 PM
Starter Woes - Remote Starter Solenoid Ants68 Electrical & Wiring 7 Mar 23rd, 14 10:49 PM
remote starter solenoid just clicking....not starting Gossamer454 Electrical & Wiring 27 Oct 8th, 13 12:57 PM
1983 Buick Regal Starter Solenoid Issues Ethan1 Misc (NON CHEVELLE AUTOMOTIVE TECH) 2 Jul 10th, 13 11:14 AM
