Tail light rear right Pigtail issue 1970 - Chevelle Tech
  • 1 Post By De70
post #1 of 4 (permalink) Old Apr 1st, 19, 9:30 AM Thread Starter
I have a right rear tail light socket issue. On original and replacement new socket I only have running lights. Stripping the wires everything works fine using just a test light. Have stop, turn signal and running lights. When I wire to the socket I have nothing. I changed to a few different new 1157 bulbs which do not light. The exterior tailight plug is not metal on the socket to attach another ground wire. I had to use needle nose to remove the old socket from the front. Access behind is restricted by a bottom rear bumper bracket. So putting the new tailight plug twist socket back is going to present a challenge. The bumper bracket has a bolt that goes up and into the lens housing. The bolt just spins and I cannot remove it. It does slide a small bit side to side. If it were out of the way I could slide my hand up to put the socket back in easily. So any advice on my electrical issue and getting the bracket out? Obviously I am getting current to the rear which eliminates a bad turn signal switch or brake switch issue. And any tips on getting the rear bottom bracket off to tail lamp without an entire bumper removal would be great.
De70 is offline
post #2 of 4 (permalink) Old Apr 1st, 19, 11:17 AM
Re: Tail light rear right Pigtail issue 1970
Sounds like you need to figure out a way to get the ground to the bulb base.
Maybe just pull the bumper.
post #3 of 4 (permalink) Old Jul 26th, 19, 2:45 PM Thread Starter
Ended up I needed a new turn signal switch as it affected stop and turn signal. I bought a new Delco wiring harness and put it through the column. No problems fixed the issue I had.
Kirk's67SS likes this.
De70 is offline
post #4 of 4 (permalink) Old Dec 29th, 19, 2:28 PM Thread Starter
Tailights work fine now. It was a bad harness / turn signal switch replaced. Check out this pic pretty cool This is actually a special photography pic called Light Painting. My friend is a professional photographer and he stopped over and took this shot for fun. A bit overkill adding an effect but pretty funny. At least my lights are normal and work fine.
De70 is offline
1970 Chevelle "flat" tail light GotGrunt What's it worth? 8 Jun 26th, 17 11:28 PM
67 Chevelle rear tail light bezel install question jdcastig Body Shop 4 Dec 29th, 16 8:42 PM
69 tail light & lens question Randall B. Body Shop 4 May 9th, 15 8:15 PM
Tail light issue TheRoger Electrical & Wiring 21 Aug 24th, 13 4:07 PM
64 Impala Tail Light Question. rocks66ss Electrical & Wiring 5 Aug 22nd, 13 9:06 PM
