starting situation - Chevelle Tech
 6Likes
post #1 of 22 (permalink) Old Mar 28th, 19, 4:00 PM Thread Starter
Kris
starting situation
Hey guys, I have a higher compression BBC and cannot get it to start. I got the battery checked and it is OK. Perhaps my starter is weak? OR do I need one if them hancy AGM batteries? Here is some vids..
What I have...
What I want..
13-1 compression 482 BBC (.100 bored over block filled)4 bolt main with good forged solid internals, square port heads, big solid roller camshaft ([email protected] intake/[email protected] ex .761 lift intake .707 exhaust 109 LSA),Weiand team G with 4150 flange, Holley model # 0-9380 850 cfm, 2 inch primary Hooker super comp headers with 12 inch collector extensions, TH-400 fully manual VB, Freakshow 4000 stall converter,4:11 gears
hear it running https://www.youtube.com/watch?v=azck_IGNLaU
MonteMan454 is offline
post #2 of 22 (permalink) Old Mar 28th, 19, 5:10 PM
Greg.
Re: starting situation
Kris it sounds to me like a low Battery / not enough Power to turn it over fast enough
Starter sounds like it is doing it's job in winging it over just not Fast enough
Do you have a Booster Pack
if not I have 2 and could drop by with them
67 Chevelle Malibu SS Cdn
Born 283 / PG / A51
Now 468/Th400 2,500 stall/ S60 3.70 Gs
Prev Best on M/T S/R #6641 street Tires/Dress 2016/10/9
60' = 1.720
1/8 = 7.747 et / 89 mph
1/4 = 12.112 et / 112 mph
NEW Best on M/T ET S/S #3454 street Tires/Dress 2018/05/20
60' = 1.664
1/8 = 7.532 et / 91 mph
1/4 = 11.814 et / 115 mph
Kirk's67SS is online now
post #3 of 22 (permalink) Old Mar 29th, 19, 7:55 AM Thread Starter
Kris
Hey Kirk, I might take you up on that offer! I tried adding more juice by using a smaller battery charger and it's activate function (starting mode) but it didn't improve anything. I have heard that you really need a large floor style charger to boost up the amps enough.
I am thinking these are some things I could try;
-use your booster pack and see if it makes a difference (I have a booster pack but I think it is dead now)
-borrow my friends Hitachi starter that he had on the current engine and see if it turns over better. This starter actually worked on this exact engine. So this would let me know if it is the starter
-go to Costco and buy a battery of similar size (900 cold cranking amps and wire it in parallel with booster cables. If it doesn't work return the battery.
-run battery directly to the starter using booster cables
-perform voltage drop test again
Kirk's67SS likes this.
post #4 of 22 (permalink) Old Mar 29th, 19, 8:25 AM
Are you running locked timing? If so, try a points distributor with the mechanical advance springs removed. It will retard during start and then go to full advance once spinning at idle..
The points distributor triggering a CD box like the Accel, MSD will work just as good as an hei..
hydro462 is offline
post #5 of 22 (permalink) Old Mar 29th, 19, 9:42 AM Thread Starter
Kris
Hello Jeff, it is a locked out HEI unit. I am trying to turn over the starter and build up engine speed and then hit the IGN button..
I have a older Crane IGN box that I could buy a IGN retard module.
post #6 of 22 (permalink) Old Mar 29th, 19, 6:52 PM
"Locked out timing", and, the voltmeter goes straight to zero when the starter is actuated. No wonder.
Dave Ray is offline
post #7 of 22 (permalink) Old Mar 31st, 19, 9:52 AM
Greg.
Kris any good news on your problem ?
Born 283 / PG / A51
60' = 1.720
60' = 1.664
post #8 of 22 (permalink) Old Mar 31st, 19, 11:31 PM
Devin
What do you have for battery cables? My son has been fighting a slow crank hot start issue in his 11:1 327. He had already upgraded starter, bought a new battery, installed a brand F solenoid, all to no avail. Recently he upgraded his battery cables from parts store quality ones to custom made 0 gauge. The problem has been solved with that so far as we can tell.
Devin
LKN BCK likes this.
64SS427 is offline
post #9 of 22 (permalink) Old Apr 1st, 19, 8:17 AM Thread Starter
Kris
Hey guys, no news..I wasn't at my place for most of last week..I will fist try the other starter and see how that goes..I am hoping to pick it up later this week. If that doesn't work, then perhaps I will borrow your jump pack Kirk. ..I guess Jump packs typically have around 300-700 amps? Right now my battery is a 78DT model group with around 800 cold cranking amps. The jump pack might give me the extra amps to see if it is a battery problem.
Perhaps I am low on amps, the guy who had this engine before (with no starting problems) used a AGM style "red top" battery like this-
https://www.bigtimebattery.com/store...g_Battery.html
I am hoping that perhaps if I need another battery then I could just wire in another 78DT in parallel ..
The battery cables are the large welding cables.It actually turned over pretty quick on the old engine which probably had a little less compression..So, I think that perhaps the wiring is OK but I will check it again..
this is a old video of the TCI starter I was using for awhile.
The timing at this moment might be locked out but at like 12 degrees..It is a drag car so that is why it is locked out.
post #10 of 22 (permalink) Old Apr 6th, 19, 1:11 PM Thread Starter
Kris
If it doesn't start with this high powered unit then it is something else..
mino65 likes this.
post #11 of 22 (permalink) Old Apr 8th, 19, 8:21 AM Thread Starter
Kris
Well it did turn over quicker for a bit (with the new starter) but then reverted back to the slow turning over..
I will borrow Greg's "battery jump pack" and see if the additional amperage makes a difference..
post #12 of 22 (permalink) Old Apr 8th, 19, 8:33 AM
Lew
Maybe too much initial timing? Try moving the timing back a little see if that helps.
Lew540 is offline
post #13 of 22 (permalink) Old Apr 8th, 19, 9:46 AM Thread Starter
Kris
Thanks Lew, I am also going to re-verify dizzy position (dizzy has been moved around quite a bit now).
I will put it at 12 degrees or so.
post #14 of 22 (permalink) Old Apr 16th, 19, 7:40 AM Thread Starter
Kris
Hey guys, I tried Greg's 500 amp jump pack and it made a difference! I also changed starters and there wasn't a huge difference but I think I will need 2 batteries..
post #15 of 22 (permalink) Old Apr 16th, 19, 8:40 AM
I never had an issue with my powermaster 9400 starter and 1 Odyssey battery. Cranked my 15:1 565 without issue.
Ray
http://s30.photobucket.com/albums/c3...t=DSC01615.jpg
bracketchev1221 is offline
quadrajet starting issue 350300 Engine 17 Nov 27th, 14 12:19 PM
Starting a motor that has sat for 3 years booboo70 Engine 15 Sep 30th, 14 4:01 PM
Starting Problem 65elkysurf Chevelle Tech 8 Sep 23rd, 14 10:40 AM
Big Block Starting issues twalker Engine 6 May 28th, 14 11:38 AM
