Stereo and Amp install - Chevelle Tech
post #1 of 4 (permalink) Old Mar 26th, 19, 3:55 PM Thread Starter
Jon
I have finally gotten tired of the bad sound on my factory 8 track. I have decided that I am going to add an aftermarket head unit and Amp in the trunk of my chevelle. I want to keep the installation as discrete as possible, but I need someone to sanity check me.
I have a reproduction battery in my car with sidepost terminals. I was thinking that I could pull power off of the starter terminal instead of the battery to keep the battery connection looking OEM. The concern that I have come up with is that I don't think there is anywhere under the hood to discretely mount the fuse for the AMP. I want to run black 4ga wire (I will label it on the terminal) From the starter into the cab of the car through the hole for the speedo cable. I could put the fuse behind the dash, but I am worried I would have several feet of unfused wire that could cause a problem if it were to get frayed and hit a ground. I was thinking I could possible use 8ga Fusible link at the starter, but I am not sure that it would work for this application.
Can anyone please sanity check this idea for me. Thanks in advance.
1972 Chevelle SS 454 "W" code
JChilders is offline
post #2 of 4 (permalink) Old Mar 26th, 19, 7:19 PM
Levon
Re: Stereo and Amp install
Jon, I ran mine from the junction on the rad support (behind the battery), between the passenger fender and inner fender down the frame rail and into the trunk. Fused it near the junction block. No one ever noticed it.
Levon Hovagimian
Team Chevelle #279
1966 427 Corvette SOLD
Priddis, Ab. Canada
My Showroom
LevonH is offline
post #3 of 4 (permalink) Old Mar 27th, 19, 8:18 AM Thread Starter
Jon
The 72 doesn't have a junction block. Otherwise that would have been a perfect spot. The positive battery cable runs straight to the starter.
post #4 of 4 (permalink) Old Apr 3rd, 19, 10:56 PM
Frank
My recommendation would be to attach to the horn relay, with a fuse close by. Definitely want a fuse on a heavy gauge wire before it passes through sheet metal that could easily cut the insulation and cause a short and subsequent fire.
If attached to the starter solenoid, the fuse should be close and in the engine bay, before the wire breaches the firewall.
-Frank
1970 Chevelle Malibu, one family owner
355 SBC, XE262H cam, Performer RPM heads, MSD HEI, TH200-4R trans, 3.55:1 Posi, digital gauges
Malibu70 is offline
1964 El Camino Stereo Install w7qhhcf Electrical & Wiring 8 May 9th, 17 6:37 PM
1969 37 amp to 61 amp alternator robpp Electrical & Wiring 9 Jul 27th, 16 5:28 PM
Stereo Amp wiring in ElCo questions JPS Electrical & Wiring 4 Apr 27th, 14 10:06 PM
Dual amp audio with a Retro Sound stereo? chevyninja Electrical & Wiring 14 Feb 14th, 13 9:27 AM
Need some advice, helping my son get his first stereo together ddeennis Bench Racing 23 Feb 6th, 13 9:12 PM
