Headlight relay Wire size - Chevelle Tech
 2Likes
  • 1 Post By 69SS454
  • 1 Post By Malibu70
post #1 of 11 (permalink) Old Mar 26th, 19, 3:37 PM Thread Starter
Guys, I purchased the relays, now I am trying to get a straight answer on wire size for each terminal.
Battery to relay = what ga?
all other wiring from relay= what ga?
I have some saying 8ga from the battery, some say 12 ga, big difference in price.
Can you help me out
1966 Chevelle.
davehurst is offline
post #2 of 11 (permalink) Old Mar 26th, 19, 3:46 PM
Re: Headlight relay Wire size
14 ga is 35 amps, 12 ga is 40 amps, 10 ga is 55 amps, 8 ga is 80 amps, 6 ga is 105 amps.
DJsSS likes this.
69SS454 is offline
post #3 of 11 (permalink) Old Mar 26th, 19, 3:50 PM
Hi Dave -
I just did this conversion a couple of months ago. I don't remember the gauge wire used, but I know it wasn't 8 - in fact it might have been 18. And looking at Mad's wiring kit, I believe they're using 18. I'm running both headlights on each side on a 10 amp fuse, and when I checked the load it was between 6-7 amps. 18 gauge is rated for 10 amps, so that should be sufficient - if you really wanted to be sure, 12 would be plenty.
jim
Jim's69Ragtop is offline
post #4 of 11 (permalink) Old Mar 26th, 19, 5:05 PM
Ideally you want to use 12 awg for the battery power to the relay and from the relay to the headlight itself.
For the trigger input line, you can use 16-18 awg.
lucifershammer is offline
post #5 of 11 (permalink) Old Apr 3rd, 19, 10:38 PM
Frank
Figure the amount of power the lights and relays will use, plus the lengths of wire and the operating temperatures (moderate temp in this case behind the radiator support). I would recommend THHN or XHHWinsulated wire good to 170F temps.
Headlights on low pull between 35w to 45w (3.2A) each bulb, high beams about 65w (4.8A) each. Two low beam bulbs would draw 6.5A. Two high beam bulbs pull right about 10A.
My recommendation would be to pull power from the horn relay and not the battery. When the engine is running, the alternator provides power directly to the horn relay over 10g wire, then to the battery through a second 10g wire (on the 1970 model car).
Battery to high beam relay: draw of 10A for two high beam or 20A for four high beams. I would recommend wire for the battery to high beam relay of 10g or 12g up to 10 feet in length.
Battery to low beam relay: 6.5A for two low beams. Recommend 12g or 14g wire.
Relays to each headlight lead, low or high beam: 14g wire. This size wire will support the 5A each bulb can draw. The factory wire to each low beam and high beam connection in 1970 was 16g wire, smaller than my proposal of 14g.
Between the power source and relay, for circuit overload protection I suggest a self-resetting circuit breaker instead of a fuse. Low beam relay can be protected with a 20A circuit breaker such as Littelfuse 20 Amp Circuit Breaker UCB20BP ($5), while the high beam could use a 30A breaker Littelfuse 30 Amp Circuit Breaker UCB30BP ($5).
Headlight sockets could be replaced with Dorman Conduct-Tite Headlight Socket 85810 ($3) or equivalent.
I did this headlight relay conversion in 2007 and have been happy with its performance.
red68chevL likes this.
-Frank
1970 Chevelle Malibu purchased new in 1970
355 SBC, XE262H cam, Performer RPM heads, MSD HEI, TH200-4R trans, 3.55:1 Posi, digital gauges, QA1 coilovers
Malibu70 is offline
post #6 of 11 (permalink) Old Apr 4th, 19, 3:38 PM
Louis
I would use 14 gauge from the horn relay to the relay contacts and from the relay contacts to the headlights and 18 gauge on the relay coil.
Louis
Original owner
lg1969 is offline
post #7 of 11 (permalink) Old Apr 4th, 19, 4:07 PM
Eddie
12gauge for battery to relay (fused), relay to headlights and ground, trigger wire 14 or 16gauge. This is how I've done on several cars and I haven't had any issues. Wires are not getting warm and lights are working fine without flickering.
Eddie K is online now
post #8 of 11 (permalink) Old Apr 4th, 19, 8:33 PM
Ideally, you will use copper bars as wide as the car is. In reality, 12 gauge or bigger (lower number) will do perfectly fine.
'71 chevelle, 468, TH400, 12 bolt posi w/3.08's, drinks a lot of 87 octane.
v8440 is offline
post #9 of 11 (permalink) Old Apr 4th, 19, 8:59 PM
Building wire such as THHN or XHHW has fewer thicker strands, is less flexible and THHN coating will harden and chip off over time when exposed to heat cycles. And less flexible means it could vibrate out of things.
Search for marine wire on eBay. They sell lengths in packs, pick your needed colors. Much better flexible high strand wire for auto use.
LS1tech.com supermoderator.
How may I help you?
1999 Trans Am-500hp
paul bell is offline
post #10 of 11 (permalink) Old Apr 4th, 19, 9:48 PM
Troy
senna is online now
post #11 of 11 (permalink) Old Apr 5th, 19, 12:39 AM
Agreed. I like to use MTW wire or GXL as it's readily available on EBay in any color/gauge you want.
Scott W.
Electrical Engineer
700R4
This is how we roll:
red68chevL is offline
This Thread is more than 430 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
65 Chevelle wiring problem Timh Electrical & Wiring 18 Oct 12th, 17 10:04 PM
Adding a Relay to Electric Fan Skier_Bob Electrical & Wiring 5 Jan 22nd, 17 3:50 PM
Welding wire size? Va72Chevelle Body Shop 6 Nov 25th, 14 6:03 PM
Wire size... What size is it? Todd79 Electrical & Wiring 9 Jun 11th, 14 10:41 PM
horn relay ground wire oldgm Electrical & Wiring 4 Nov 19th, 13 11:35 PM
