Power window switch repair???? - Chevelle Tech
  • 1 Post By 72soft-top
post #1 of 3 (permalink) Old Mar 24th, 19, 7:15 PM Thread Starter
So installed a GM power window and power lock system today. The NOS 4 switch pack I purchased many years ago does not raise the drivers window. All other windows worked fine. Changed the switch with another I had and it worked. So. Can the switch bezels be removed to swap/repair the switch?
Team Chevelle Member (18 years and counting...)
72soft-top is offline
post #2 of 3 (permalink) Old Mar 26th, 19, 5:22 PM Thread Starter
So I bent the tabs on the back of the switch to open it up and inspect the issue. The switch for the drivers window had a slight fit up flaw that did not allow for full rotation to make contact. Added a little bead of solder to the contact area and it works perfectly. Just thought I’d share
69SHEVL likes this.
post #3 of 3 (permalink) Old Mar 26th, 19, 5:26 PM
Thumbs up Re: Power window switch repair????
Glad to see all 69 doors have power window regulator holes punched Ga69abody Restoration Corner 4 Jul 23rd, 17 11:51 PM
No power to headlights Baron67 Electrical & Wiring 38 May 7th, 17 3:21 PM
66 chevelle convertible rear power window switch location klauslutz Restoration Corner 4 Nov 10th, 14 11:10 PM
Switching to a power rear window? sped01 Wagons & Four Doors 12 Aug 28th, 13 6:17 PM
67 chevelle power window switch location fyrengineer Interiors 1 Apr 3rd, 13 5:36 PM
