Harness connector - Chevelle Tech
post #1 of 4 (permalink) Old Mar 21st, 19, 7:21 AM Thread Starter
Don
Question Harness connector
Anybody have or know where to get a "66" female turn signal connector?
Trying to set up a hazard warning flasher,I see a couple flasher units on Ebay,one is a new repo but it's for a full size Chevy and doesn't have the correct connectors for Chevelle. Rich L79 verified this for me as he has the repo and had to scrounge up Chevelle connectors to make it work. Kind of leary about the originals listed on Ebay,"works fine" isn't always the case.
Of course I've checked with American Autowire and Lectric Limited and they won't sell the connectors or terminals seperatly,I have an old signal switch with the male end so I'd be OK there,Rich thinks "64-66" connectors are the same? Also wondering if the male and female terminals are available anywhere so if I found a connector that was corroded I could replace them.
Rich said the repo on Ebay seems to be good quality,so I'm considering that route. I talked to someone else and was told that the original kits from G.M. were just like the repo unit,but they came with the Chevelle connectors and terminals which had to be installed as shown in step 2 of the instructions for Chevelle.
Don B is offline
post #2 of 4 (permalink) Old Mar 21st, 19, 10:14 AM
steve
Re: Harness connector
I rebuilt my 1966 Chevelle entirely. But still , a picture of what exactly you need would help. If you are referring to the U shaped connectors under the dash I think Rich is correct that 64-66 connectors are the same and you are able to swap in various wires to make the correct terminals/connections...
64tempestwagon is offline
post #3 of 4 (permalink) Old Mar 21st, 19, 6:20 PM Thread Starter
Don
Yes,half Moon or U shaped is what I was referring to.
Don B is offline
post #4 of 4 (permalink) Old Mar 21st, 19, 7:47 PM
Rich
What Don is after is the top one as appears in this photo. This is the half moon connector that is part of the underdash harness.
NCOA member #220
ACES member #1670
Team Chevelle #998
Rich Cummings
Rich-L79 is online now
1972 steering column harness JWagner Electrical & Wiring 4 Aug 31st, 17 12:53 PM
My Dash Harness connector wires broke? Dnrice Electrical & Wiring 6 Dec 14th, 14 9:41 PM
Remove Main Wiring Harness Connector??? man44a Electrical & Wiring 5 Sep 18th, 13 5:38 PM
Headlights bbowen1 Electrical & Wiring 6 Mar 26th, 13 6:19 PM
