1968 396 Orange wire ID please. - Chevelle Tech
 17Likes
  • 4 Post By DUTCH MAX HEADWORK
  • 3 Post By skreddy
  • 2 Post By any4xx
  • 4 Post By Coppertop
  • 1 Post By Billdini
  • 2 Post By shovelrick
post #1 of 15 (permalink) Old Mar 18th, 19, 10:27 PM Thread Starter
In the engine harness on the passenger side I have this Orange wire that is long enough to go to the front of the motor.. What does it go to please?
68SuperSport* is offline
post #2 of 15 (permalink) Old Mar 18th, 19, 10:29 PM Thread Starter
Why does this website flip my photos? Aggravating
post #3 of 15 (permalink) Old Mar 18th, 19, 11:29 PM
Re: 1968 396 Orange wire ID please.
It's your phone, not the site.
David
davewho1 is offline
post #4 of 15 (permalink) Old Mar 18th, 19, 11:57 PM
Al
Hold your phone the other way.....seriously. I mean it. Your phone thought it was upside down, it puts a code in the data that tells other devices which way is up. Try it, you'll get the hang of how to hold it.
How does your blower motor work? That wire might go there.
DUTCH MAX HEADWORK is offline
post #5 of 15 (permalink) Old Mar 19th, 19, 9:27 AM
Ben
As said, that looks like the blower motor wire. My 68 wire looks identical.
HKalin, shovelrick and 68-13427 like this.
No car yet; currently looking for 66-69 project/driver.
skreddy is offline
post #6 of 15 (permalink) Old Mar 19th, 19, 11:32 AM
Blower motor. Plugs in under the passenger side fender.
HKalin and shovelrick like this.
any4xx is offline
post #7 of 15 (permalink) Old Mar 19th, 19, 2:53 PM
Blower motor power feed for non-A/C vehicles
Coppertop is offline
post #8 of 15 (permalink) Old Mar 20th, 19, 10:02 PM Thread Starter
Ok. Makes sense. My car is an A/C car . So I guess I won't use it?. On my old harness the Orange wire is there, but the connector is snipped off. I thought maybe it was cut when the motor was pulled.
post #9 of 15 (permalink) Old Mar 21st, 19, 10:29 PM
So I suspect that you installed a new engine wiring harness. That wire is for the blower motor "IF" you don't have AC. I called M&H and they said to just cut it off where it goes into the harness tape and that is what the factory did with AC cars. 68 has a separate harness for AC cars that comes through the cowl which has another power lead wire with the same connector and a ground that goes to the motor. I think they are purple and black wires. Power also is supplied with a large gauge feed wire (black) to that harness from the horn relay with a inline fuse connector. 68's are a challenge and can be very unique. Welcome to the 68 club....LOL
68SuperSport* likes this.
Billdini is offline
post #10 of 15 (permalink) Old Mar 22nd, 19, 6:57 AM
bob
On my 67 with factory A/C with original wiring harness the orange blower wire is taped in the harness going to the starter just above the exhaust manifold.
bobm67 is offline
post #11 of 15 (permalink) Old Mar 22nd, 19, 8:17 AM
rick
Instead of cutting the wire maybe tape it back into the harness in case you need it for something later...never know?
HKalin and paul bell like this.
shovelrick is offline
post #12 of 15 (permalink) Old Mar 22nd, 19, 11:54 AM
AC cars have a different heater panel then non AC. If he was to measure that orange wire with a meter he would see it has no voltage since it doesn't connect to the heater/ac panel. I've seen that wire cut on many other cars as well so it is correct to be cut off. Unless he pulled out the ac system, changed the heater/ac controls to heat only then he could never use it anyways. I cut mine off because I didn't want an unused wire laying around not to mention later someone will ask "Whats that wire for" ... LOL
Billdini is offline
post #13 of 15 (permalink) Old Mar 22nd, 19, 5:40 PM
rick
Not trying to hijack the OP's question but I'll be adding after market a/c to my 68 non a/c Malibu, would that Or. wire be helpful ? or not needed? cause I'll chop mine off too!
post #14 of 15 (permalink) Old Mar 22nd, 19, 6:51 PM
Rick I would be very careful cutting that wire without talking to the company that sells the AC conversion. Do they provide a new Ac/heater control panel, wiring harness and main power lead. Probably not. They may use that for their blower. In any case call them and get advice or download the installation guide and see what is involved.
shovelrick likes this.
Billdini is offline
post #15 of 15 (permalink) Old Mar 23rd, 19, 11:48 AM
So Rick relative to your question this system does include all wiring, controls and parts which is all inclusive. It does state to cut the original heater wire but I would just tape it to the engine harness because it is not used but you might go back to stock. So I stand corrected. Below is a link to the installation manual for the classic air unit for a 68
https://www.classicautoair.com/shop/...ioning-system/
Billdini is offline
This Thread is more than 441 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
1968 396 375hp EG Code L78 Motor F1 Temporary Free Classifieds 6 Jul 17th, 19 8:07 PM
1968 Clutch Fan or Standard 4 Blade (396) Yes or No neilv Heating & Cooling 2 Feb 27th, 19 3:19 PM
1968 Chevelle SS 396 Build Sheet Found Krateness Tag Team 3 Apr 24th, 18 9:28 AM
1968 SS 396 Barn Find 1968 SS 396 Expinosa New Member Introductions 26 Mar 10th, 17 9:40 PM
1968 How hard is it to get to fuel gauge sender wire on tank? Dnrice Electrical & Wiring 2 Jan 31st, 15 4:48 PM
