70 fuel guage wire color? behind dash - Chevelle Tech
post #1 of 4 (permalink) Old Mar 18th, 19, 7:09 PM Thread Starter
Rob
Question 70 fuel guage wire color? behind dash
70 chevelle Malibu sweep style gauge cluster, what color wire goes to the fuel level gauge, where does it run under the dash? harness? fuse box? steering column?
Ive got a pink and lime green wire coming from the gauge area,don't know what it went to?
Fuel level gauge is not working reason im asking. Ive read a few threads on the testing part.
Thanks for any help
Rob
Plan B Kill It With Fire
Strip Poker 388 is offline
post #2 of 4 (permalink) Old Mar 18th, 19, 10:24 PM
Hunter
Re: 70 fuel guage wire color? behind dash
Thanks for any help
Rob
In my personal experience, the pink wire is usually ignition wire, so I would assume the other wire is your fuel gauge wire. I can't remember what color mine was but I also have an American Autowire kit. Not sure if it makes a difference or not...
Sent from my Phone 2 using Tapatalk
Cubsfan3493 is offline
post #3 of 4 (permalink) Old Mar 18th, 19, 10:43 PM
My AAW kit has a tan wire between the fuel sender in the tank and the gauge. The original harness from 1970 was also tan for this circuit. Mine runs from the rear of the vehicle, across the floor pan in a flat, black rubber ribbon wire protector and then up inside a rubber tube next to the fuse block. It pops out of the rubber tube along with many other wires and they go various, as required places after that.
Yes, pink is typically a 12 volt positive wire that is only hot with the key on.
Lime green at the gauge cluster is the high beam indicator light. Regular green is the temperature gauge, if equipped.
B52bombardier1 is online now
post #4 of 4 (permalink) Old Mar 19th, 19, 5:58 PM Thread Starter
Rob
Thanks for the info, I seem to remember the lime green wire on radiator support going to the high beams also.ill ck see if indicator is working,blue light? It has the idiot light for engine temp, I assume its not hooked to anything with no sensor for it anymore. Might be a stereo wire not hooked up either.
Ill have to pull the cover off below steering column see where it goes,tan wire?
Does anybody have a wiring schematic for that area ,column/fuse/dash cluster?
At the sending unit I read 8.4vts on the hot side/tan wire, i ran outa time to finish testing it.
Thanks for all the help
Rob
This Thread is more than 377 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
E-Street 2 Write-up 69Chvll EFI 72 Dec 22nd, 19 6:32 PM
Dash wire over glove box ? 19733 Electrical & Wiring 0 Feb 17th, 17 5:16 PM
1970 SS Dash Conversion Mystery Wire booboo70 Electrical & Wiring 3 Nov 13th, 14 12:31 PM
fuel pressure guage Smokumjames Troubleshooting 5 Sep 22nd, 14 9:36 PM
Need help wiring. Amp guage with a 1 wire alternator N2ROW Electrical & Wiring 13 Jun 4th, 14 11:13 AM
