dim headlights - Chevelle Tech
 6Likes
  • 3 Post By RealRed70
  • 1 Post By blm
  • 1 Post By 66sc
  • 1 Post By 70montee
post #1 of 14 (permalink) Old Mar 6th, 19, 1:48 PM Thread Starter
dim headlights
What is causing dim headlights. New battery and new alternator and nothing has changed. It is on a 1972 Chevelle
gaul1972 is offline
post #2 of 14 (permalink) Old Mar 6th, 19, 2:07 PM
Re: dim headlights
Voltage regulator on the firewall may be bad if your not running stereo amps or any other items that draw massive current.
oldcutlass is online now
post #3 of 14 (permalink) Old Mar 6th, 19, 3:21 PM
Al
Re: dim headlights
Do you own a volt/ohm meter? If not, go buy a cheapy and we'll run you through some tests.
Auto ranging will make life easier if you know Jack. Soon, you'll be a pro.https://smile.amazon.com/gp/prime/ha...t-bbf_1_glance
Non auto ranging. It will take an extra minute to show you how to set this one....https://smile.amazon.com/AstroAI-Dig...gateway&sr=8-3
An electrical test light comes in handy for other auto electrical diagnosis, but don't need one for your issue and if you know how to use a meter all the test light can do is sometimes speed up the diagnosis.https://smile.amazon.com/s?k=auto+te...b_sb_ss_i_3_15
post #4 of 14 (permalink) Old Mar 6th, 19, 3:23 PM
Re: dim headlights
Poor grounds will give you dim lights.
blm, davewho1 and B52bombardier1 like this.
RealRed70 is offline
post #5 of 14 (permalink) Old Mar 6th, 19, 3:33 PM Thread Starter
Re: dim headlights
I have a meter. the dash lights are also dim
gaul1972 is offline
post #6 of 14 (permalink) Old Mar 6th, 19, 5:00 PM
Mark
Re: dim headlights
Check the body ground to the fender from the negative post. Many of these are omitted through the years at battery replacement time. Check voltage at the headlight connectors to confirm supply and grounds. Should read approx. 12.5 to 13.5 volts at connector when running. If ok, adding a relay will brighten them up significantly. These old systems drop a lot of voltage through the headlight switch and bad connections that develop through time.Using a relay will supply 14.5 volts directly to the headlights which will make them appear almost 30-50% brighter.
modern malibu is online now
post #7 of 14 (permalink) Old Mar 6th, 19, 9:32 PM
Re: dim headlights
Add a temporary supplemental ground wire to a single headlight and see if the light gets brighter. If it gets brighter, you know which half of the lighting circuit needs cleaning or maintenance.
B52bombardier1 is offline
post #8 of 14 (permalink) Old Mar 6th, 19, 9:51 PM
Re: dim headlights
I put a 150 amp alternator, rewired the main harness with -10, -8, and -6 wires where applicable. Noticeable different in how bright my headlights got.
Youtube Channel.
Instagram:
Twitter:
-SS454- is online now
post #9 of 14 (permalink) Old Mar 6th, 19, 10:03 PM
blm
Re: dim headlights
Not saying this is the problem but will improve your headlights and make them much brighter. There is a mod that many here do that involves adding relays to the head light circuit. Should be very easy to find a thread about that procedure.
My guess for your problem is grounds need improved.
Kirk's67SS likes this.
blm is online now
post #10 of 14 (permalink) Old Mar 6th, 19, 10:37 PM
Kev
Re: dim headlights
Just to add to all the other good suggestions, I'd disconnect every + side connector and plug it back in, including the harness connectors at the firewall and headlight switch.
Good grounds as mentioned above are vital. When the car was built, all those body parts bolted together had clean electrical connection. Now they're rusty and no maybe bueno.
Relays are good too since in a stock system there's a much longer current path to run the lights.
The whole thing leads to electricity (energy) flows from the batt/alt in a circle from one side to the other. All the current that that goes to the lights in this case, goes from the alt to the lights and back. Nothing is lost. Bad connections may limit the current (making the lights dim) but end to end, current is the same. The point is, you need to make sure there are no bad wiring or connections all the way from and to the current source (batt/alt).
Yep, it's a pain in the butt...
-SS454- likes this.
66sc is offline
post #11 of 14 (permalink) Old Mar 7th, 19, 7:19 AM
Re: dim headlights
If lights are dim, no point in doing any thinking/asking/guessing at all. Check battery voltage with everything (including engine) off, with engine running at 2,000 RPM with everything off. Then do it again with high beams on with everything else off (including engine), then with as much stuff on as you can with engine at 2,000, High Beams, brake lights, fan at high...
List those 4 voltages, should only take 2 minutes to test.
rough estimates of them should be 12.6, 14.3, 12.2, 13.9 something like that. Basically over 13.8 when running, and under 13 when off, but always over 12 (unless cranking).
Also, how old are the bulbs, they don't get brighter after 50 years...
Pioneer4x4 is offline
post #12 of 14 (permalink) Old Mar 7th, 19, 9:04 PM Thread Starter
Re: dim headlights
Thanks for all the suggestions. I will check grounds. The headlights are at least 20 yrs old.
gaul1972 is offline
post #13 of 14 (permalink) Old Mar 8th, 19, 7:08 AM
Re: dim headlights
with dim dash lights as well, the headlight switch might be suspect, arm yourself with your meter. check battery voltage. check voltage at some fuses. should be pretty similar. then turn on headlights, and check voltage at the plug. use the ground at the plug, then try grounding at battery or alt case or something to see if you have a difference. i think you will see like a 1 volt drop, just due to old wiring. if its more, then maybe head up to the headlight switch and start testing there. I found this which might be helpful at the headlight switch.
https://www.chevelles.com/forums/27-...itch-info.html
The relay kit for the headlights is clearly worth the money. Seen a bunch of charred plugs for the headlight switch. headlights have a big load, and the relay mod will take that huge load away from the headlight switch.
gaul1972 likes this.
70montee is online now
post #14 of 14 (permalink) Old Mar 13th, 19, 1:52 AM
Bought a relay kit from EBay last year, $20 some I think it was with pre wired harness etc.
Took half an hour to install, HUGE didference in headlights, dash lights, etc 👍
yanniziomas is offline
This Thread is more than 381 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
Driver said headlights CHV69LLE Electrical & Wiring 3 Nov 19th, 16 11:02 AM
Halogen and LED conversion headlights for Chevelle Carid CARiD.com 10 May 9th, 16 11:41 PM
Headlights question... fraserfox Chevelle Tech 8 May 6th, 16 6:17 AM
Turn Signal Does not work with Headlights on 69 Chevelle deffmike Electrical & Wiring 16 Nov 7th, 15 2:38 PM
68 malibu blinker won't blink w/ headlights on Macsully Electrical & Wiring 6 Nov 10th, 14 12:56 PM
