Sanity Check - Electronic Ignition Power - Chevelle Tech
post #1 of 9 (permalink) Old Feb 25th, 19, 12:30 PM Thread Starter
Matt
Quick question - car's a '71 that came with points ignition. I'll be putting electronic in it (ala pertronix, not a full HEI cap/etc), so I'm replacing the wire from the block on the firewall to the coil+ with a non-resistor wire. When I do this, I can also remove the yellow wire that comes off the starter solenoid to coil+ (since it is just there to bypass the resistor wire when cranking) right?
Thanks!
(I'm also removing the TCS / CCS wiring from this harness; it is out of the car on the bench at the moment - no gotchas in that right? Looks straight forward to pare it out from the diagram in the service manual.)
Industrial controls engineer by day, mechanic by night, a few screws loose 24/7
'71 4-Door Malibu
My old daily, a project to be a driver again
Previously: 307 / Powerglide
Current: 307 / Muncie M20
Soon: 383 / Muncie M20
MM54 is offline
post #2 of 9 (permalink) Old Feb 25th, 19, 10:45 PM
leo
Re: Sanity Check - Electronic Ignition Power
JMHO, tape it back in the harness!
Leo Paugh
Maryland Chevelle Club #017
A.C.E.S.#3731
LeoP is offline
post #3 of 9 (permalink) Old Feb 25th, 19, 10:55 PM
You need to change the coil if your doing away with the resistance wire as per the instructions.
oldcutlass is offline
post #4 of 9 (permalink) Old Feb 25th, 19, 11:06 PM Thread Starter
Matt
I'll have the harness apart anyways (cleaning out the TCS/CCS stuff from when it was a powerglide/2bbl) so I'll remove it all-together, and replace the coil feed with a wire taped back up in the harness
Sometimes doing things the hard way is more fun (and isn't that what this is all about?)
It will be the appropriate coil to match the ignition module, no worries (I've seen what happens when people run non-resistor coils without ballast!)
'71 4-Door Malibu
MM54 is offline
post #5 of 9 (permalink) Old Feb 26th, 19, 5:50 AM
I leave the points in. Nothing wrong with them...
hydro462 is offline
post #6 of 9 (permalink) Old Feb 26th, 19, 9:42 AM
Al
I've been reading many posts about conversions from points to electronics ignition, all of them with problems. Seems the average guy wanting to eliminate points in favor of a 'trouble free' system creates more problems than he eliminates. OK GM uses electronics ignitions and has for years, but our cars were designed with a points system to include some method of reduced voltage via a ballast or wire type of resistor. Original systems used a set of contacts in the starter to deliver full voltage to the coil during starting but use a lower voltage when running.
I have installed several aftermarket electronic ignition systems in 1960 vintage cars with mixed results. The instructions were piss poor at best as to whether full 12 volts was needed at the coil or a reduced value was needed. Some of these systems have an external 'box' requiring additional wiring. Then some of these aftermarket manufactures have gone off shore with their manufacturing and use the lowest price components.
My local hi-performance shop does distributor work and has a box full of point-less electronics failed components, all from guys like us wanting something different than standard points and all are apparently garbage. As was mentioned above, leave your stock ignition system in place and be happy. Just saying... Al
alhewitt is offline
post #7 of 9 (permalink) Old Feb 26th, 19, 10:03 AM
On the other hand, it won't hurt anything to leave the bypass wire connected to the coil, it might give a little voltage boost during cranking.
post #8 of 9 (permalink) Old Feb 26th, 19, 11:06 AM
Let's not confuse two very different issues here:
1) The original, decades old idea of swapping out Points for an HEI type ignition......using QUALITY parts made in the States or Canada.
When you could get NOS or OEM parts from GM and others, this was almost a no brainer. Very high success rate, better ignition set up, and no points to worry about. Ever.
vs.
2) Having to deal with today's substandard Chinesium HEI parts.
Now, in retrospect, multiple spark discharge was largely b.s. and those boxes didn't do much, other than function as a rev limiter.
But thanks to Holley, MSD, Mallory, etc. offshoring (and in some cases, being controlled by the same, soul-less private equity firm)....we now have poor quality, Mandarin made, HEI parts to pick from when doing the conversion.
Booo........
blue_69_malibu is offline
post #9 of 9 (permalink) Old Feb 26th, 19, 4:50 PM
From a person that fixes all sorts of ignition problems and issues, day in and day out, ME, ALL PerTronix need a ballast resistor, no matter the coil used.
Now, to power up a full volts ignition system, of which, HEI is the only one that ISN'T a CD, take the two wires off the coil, tape them up, and tape them to the wiring loom over the engine, let them stay in place if you ever need them to replace the blown up Ignitors.
Then, check the IGN or IGNITION terminal on the fuse box, to ground, should only be 'hot' in ignition switch positions start and run. Then, 14 gauge wire through the firewall in a place that won't hurt the wire, directly to the positive post on the new coil, done, finished, changeable back to a resisted system easily, with NO adverse issues.
NO need to reinvent the wheel here, just simple work.
Dave Ray is offline
This Thread is more than 396 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
power windows and locks into 68-72 wagons chevygod Wagons & Four Doors 26 May 31st, 17 7:18 PM
Need Help with my Ignition! rriley Electrical & Wiring 2 Oct 18th, 12 10:52 AM
'68 power steering whamo44 Brakes, Suspension & Steering 6 Oct 11th, 12 8:19 AM
O/T GM EFI Question + Sanity Check Slowpoke70 EFI 7 Oct 9th, 12 11:22 AM
Top Ten Multimeter Tests - Part 2 of 2 TheDon Electrical & Wiring 0 Dec 22nd, 10 1:57 PM
