Right front turn signal - Chevelle Tech
 3Likes
  • 2 Post By 69SS454
  • 1 Post By glinder46
post #1 of 14 (permalink) Old Feb 20th, 19, 4:20 PM Thread Starter
George
Unhappy Right front turn signal
I have had problems in the past with turn signals but am stumped with this one. The right front turn signal does not work. Neither will the hazard signals work for the right front. The housings are new and well grounded. They worked until I had to take the gauge cluster out for a speedo problem. Not getting any voltage at all to the housing. Does anyone have any ideas? The last time I had problems was with the main connection into the cluster but it is in solid and I have no other problems.
Thanks in advance.
glinder46 is offline
post #2 of 14 (permalink) Old Feb 20th, 19, 5:24 PM
Re: Right front turn signal
What vehicle?
post #3 of 14 (permalink) Old Feb 20th, 19, 5:27 PM
Check the connector at the steering column going to the turn signal switch. It might not be plugged in all the way. The right front turn wire is dark blue. Check this wire with a test light. If it flashes there, then check the same dark blue wire at the fire wall bulk head connector.
69SS454 is offline
post #4 of 14 (permalink) Old Feb 20th, 19, 5:45 PM
Ryan
Have you checked for a severed wire around the cluster/dash?
I find that if I carefully trace the harness from end to end, putting eyes on every inch of the wiring and every single connector/connection, I often find the culprit without any electrical testing at all in the case of no power conditions.
Finding electrical gremlins is a special kind of torture, so I feel your frustration.
283 V8
Powerglide 2-Speed Automatic
hrspwrjunkie is offline
post #5 of 14 (permalink) Old Feb 20th, 19, 10:59 PM Thread Starter
George
Can you tell me how the circuit works.
post #6 of 14 (permalink) Old Feb 21st, 19, 3:17 AM
You can isolate the problem with a 12v jumper wire hooked to the blue wire on the body side of the connector at the steering column. If it lights the lamp, then the issue is in the turn signal switch. If not then you need to trace the wire forward to see where the voltage is lost.
oldcutlass is offline
post #7 of 14 (permalink) Old Feb 21st, 19, 11:27 AM Thread Starter
George
I'll start tracing the wiring. Will be a few days, Thanks to all
post #8 of 14 (permalink) Old Feb 21st, 19, 3:02 PM
If you can, post what vehicle you are working with.
This can be real important as some may look at this thread and without a year, make and model, it's just too general of a question and may not get answered or get you on the path to getting the issue resolved.
Another question I have is, does the instrument panel's right turn signal light come on with the flashers activated or when the right turn signal is turned on ?.
While the below is for a 69 Nova, the basic setup is the same for a 69 Chevelle BUT we don't know if that is what you are having issues with.
Turn Signal Circuit:
Emergency Flasher Circuit:
Always working on something:
Jim Streib is offline
post #9 of 14 (permalink) Old Feb 21st, 19, 3:49 PM Thread Starter
George
I sent a 12v signal thru the connector to both L&R turn signals. The right one was dead, so as you suggest I will look downstream. I find it hard to believe it is the bulkhead connector since it was recently apart and cleaned so I'll start under the hood.
Thanks again,
It wouldn't be that bad if it wasn't so cold.
post #10 of 14 (permalink) Old Feb 21st, 19, 3:52 PM Thread Starter
George
Sorry, I thought that I had posted the vehicle but it is a 70 Chevelle SS 454
post #11 of 14 (permalink) Old Feb 21st, 19, 4:33 PM
Thanks again,
Yes, next place would be the bulkhead connector. Especially if it was apart.
post #12 of 14 (permalink) Old Feb 24th, 19, 4:10 PM Thread Starter
George
I finally solved the problem. Sent a 12v signal thru the bulkhead connector to the dark blue right turn signal wire and it still didn't work. Removed the battery and found the factory connector to the lamp had the dark blue GM spade connector had released from the connector and wasn't supplying power. All the way to the end of the circuit.
Thanks, Everyone
George Linder
davewho1 likes this.
post #13 of 14 (permalink) Old Feb 24th, 19, 9:17 PM
Thanks, Everyone
George Linder
Just to expand on things, is in your situation the front turn signal light did not work due to the connection issue by the battery. The indash right turn signal light should have been working as this part of the circuit was before your issue.
Glad you got things figured out.
post #14 of 14 (permalink) Old Feb 24th, 19, 9:59 PM
Glad you found it.
This Thread is more than 397 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
Turn signal and horn problem steveleb66 Electrical & Wiring 2 Mar 24th, 18 2:49 PM
Turn signal problem 69che Electrical & Wiring 1 Jan 14th, 17 9:24 PM
Front Turn Signal/ Marker Lamps 1970-Cloned Electrical & Wiring 3 Mar 1st, 15 2:52 PM
70 Front right turn signal not working psi3000 Electrical & Wiring 3 Sep 8th, 14 12:37 AM
72 Chevelle Wagon Turn signal issue skongolf Electrical & Wiring 2 Mar 23rd, 14 11:45 AM
