Fuses - Chevelle Tech
 2Likes
  • 2 Post By wlcarroll
post #1 of 9 (permalink) Old Feb 18th, 19, 10:43 PM Thread Starter
Terry
Fuses
Hi All, I am finally at the point of re-installing my instrument panel. I bought a AAW stock replacement harness, so it uses glass fuses. I never gave the fuses a second thought as i was wiring up the gauges and such, but now find myself in need of fuses. I did the google search, a lot of amazon stuff, one ad says " you will like our quick blow fuses". Hmm, no i won't. So, my question is, where can i get good quality glass fuses for my '68? Oh, i went looking locally for bulbs, for tail lights, etc. 1156 and 1157's $5.99 for 2 bulbs. I went to Bulbs and batteries because i heard they had discounts, Whoa Nelly, $ 4.95 each. I found bulbs for .49 cents on Rockauto. Just need to find the fuses. Terry
68-13427 is online now
post #2 of 9 (permalink) Old Feb 18th, 19, 10:55 PM
Al
Re: Fuses
For the most part, most glass fusses are quick blow and that's what you want.
I've always used BUSS fuses...I guess the are called Bussman. https://smile.amazon.com/Bussmann-Gl...ds=glass+fuses
That kit is probably enough to do your entire fuse box. You may need 1 more smaller fuse to get the complete set. Walmart probably has best prices....check it out if you're into Walley. Give you a link so you can compare prices with others...https://www.walmart.com/ip/BUSS-AGC5...TY-5/495970232
DUTCH MAX HEADWORK is offline
post #3 of 9 (permalink) Old Feb 19th, 19, 12:00 AM Thread Starter
Terry
Re: Fuses
Al, I always used buss fuses in the past myself, but i saw bussman instead and thought they might be knockoffs. Nice tip on wally world carrying the fuses will save on shipping, Thanks. Terry
post #4 of 9 (permalink) Old Feb 19th, 19, 1:56 AM
Al
Re: Fuses
I think your right Terry. They fooled me. It is BUSS fuses and I think Bussman is a brand of Eaton. Looks like 2 different brands, Not sure where either are made anymore. I still get Buss at Napa. Ran a search and saw Walmart had them too. https://www.waytekwire.com/item/2227...-Series-NO-44/
post #5 of 9 (permalink) Old Feb 19th, 19, 3:38 AM
Re: Fuses
OReilly sells fuses in packs of 5 or assortment packs from $2.00 - $6.00ish. Name brand Littlefuse.
https://www.oreillyauto.com/search?q...use+assortment
oldcutlass is offline
post #6 of 9 (permalink) Old Feb 19th, 19, 1:17 PM Thread Starter
Terry
Re: Fuses
I went to o'reilly first, the fuses they had were not that cheap. I live in commiefornia, everything has a greenie tax on it . I was shopping Rockauto over the weekend, wanted to buy light bulbs, fuses ,and emergency flashers, i bought the bulbs ,cheap, did not see any fuses, and after i clicked on the flashers to purchase, a pop-up comes on the screen telling me these can't be shipped to ca. because of some prop 65 B.S. Rant over. Terry
post #7 of 9 (permalink) Old Feb 19th, 19, 2:13 PM
Re: Fuses
Try epay - new and vintage:
https://www.ebay.com/sch/i.html?_fro...c&LH_PrefLoc=1
David
davewho1 is offline
post #8 of 9 (permalink) Old Feb 19th, 19, 2:29 PM
Re: Fuses
140 fuses, $10.75 at Amazon
post #9 of 9 (permalink) Old Feb 19th, 19, 3:16 PM
Re: Fuses
Buss and Bussmann are the same company, a division of Eaton.
wlcarroll is offline
This Thread is more than 369 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
color coded glass fuses roadster601 Restoration Corner 64 Jan 28th, 19 9:37 PM
Dome Light circuit (popping fuses) HELP??? Daron Craig Electrical & Wiring 14 Mar 15th, 16 2:48 PM
Flex-o-lite fans blowing 25 amp. fuses w7qhhcf Heating & Cooling 6 Sep 23rd, 15 11:57 AM
no power to switched fuses red elko Electrical & Wiring 2 Oct 2nd, 12 3:17 AM
Blowing Fuses !!!!!!! jr 1999 -- 4 Jun 30th, 99 7:09 PM
