Blowing headlight - Chevelle Tech
  • 1 Post By paul bell
post #1 of 13 (permalink) Old Feb 18th, 19, 6:27 PM Thread Starter
Blowing headlight
We rarely rarely use our headlights. In the fall I noticed the driver's headlight out. No big deal. I went ahead and bought both stock replacements from Autozone and changed them out. Turned them on to check them and both were fine. Fast forward several months to last night. When we turned them on for the first time the driver's one was out again. We have never used them since the new ones were installed. What should I check? The engine, transmission etc. on this car has been highly modified but to the best of my knowledge the wiring for the lights, etc. is all stock.
Tar Heel is offline
post #2 of 13 (permalink) Old Feb 18th, 19, 6:39 PM
Al
Re: Blowing headlight
Voltage while running. Should be about 13.5 to 14.5 volts. Bad alternator or regulator could be the cause.
Maybe crappy headlights or bad luck.
Check the plugs at the back of the headlight for power or corrosion. Maybe the light is good and you have a wiring issue.
DUTCH MAX HEADWORK is offline
post #3 of 13 (permalink) Old Feb 18th, 19, 6:44 PM
Are you sure the bulb is the problem? Maybe it's not getting power or ground.
post #4 of 13 (permalink) Old Feb 19th, 19, 2:45 AM
Or the splice junction where the 2 sets of wires meet.
oldcutlass is offline
post #5 of 13 (permalink) Old Feb 19th, 19, 8:08 AM
Wiggle the headlight connector. I've got the original harnesses for the headlights on my 64, headlights are white and bright normally but loose connection over time. Quick wiggle and they're back on.
Chances are your old headlights are fine and not blown.
*Jeff*
LQ4 / T56 Swap
Hotwire is offline
post #6 of 13 (permalink) Old Feb 19th, 19, 8:26 AM
Are you sure the headlights them selves actually don't work? It sounds almost like somewhere in the wiring is bad.
ZEN357 is offline
post #7 of 13 (permalink) Old Feb 19th, 19, 10:08 AM Thread Starter
Haven't tried that yet but definitely will before I pull the headlight out. Thank you.
2015 Chevrolet Silverado 3500HD LTZ 4WD DRW
1972 Chevelle
Tar Heel is offline
post #8 of 13 (permalink) Old Feb 19th, 19, 10:24 AM
To confirm the bulb is blown and not the harness or plug, swap it to the plug on the other side of the car.
lucifershammer likes this.
LS1tech.com supermoderator.
How may I help you?
1999 Trans Am-500hp
paul bell is offline
post #9 of 13 (permalink) Old Feb 19th, 19, 10:33 AM
Or check the bulb continuity with a multimeter. Then check for constant voltage at the lamp socket, with the headlamp switch on.
SSJohn is offline
post #10 of 13 (permalink) Old Feb 19th, 19, 10:39 AM
Troy
This is the type of diagnostics that a Power Probe ( probably others ) is an awesome tool. You can test the head light independent of the car without removing it, and test your voltage or ground etc.
66 CHEVELLE
senna is offline
post #11 of 13 (permalink) Old Feb 19th, 19, 11:27 AM Thread Starter
I have a nice voltmeter but to be honest am a novice when it comes to electrical troubleshooting. What exactly should I do to test the bulb and plug?
1972 Chevelle
Tar Heel is offline
post #12 of 13 (permalink) Old Feb 19th, 19, 2:15 PM
Also check the mount, a headlight bucket that isn't snug will vibrate and destroy the filament.
Pioneer4x4 is offline
post #13 of 13 (permalink) Old Feb 19th, 19, 2:40 PM
Al
Helpful Headlight Switch Info Coppertop Electrical & Wiring 38 Nov 17th, 18 5:08 PM
Dash lights keep blowing tiny fuse when headlight switch is turned on Dave454Chevelle Electrical & Wiring 12 Mar 12th, 18 11:36 AM
headlight switch, knob,rod problem 1966_L78 Electrical & Wiring 10 Oct 6th, 17 4:17 PM
1967 Chevelle Headlight Help! camaro-guy Restoration Corner 0 Sep 10th, 16 9:21 AM
70 Headlight Buckets Delta Body Shop 2 Sep 21st, 14 9:51 AM
