Considering Digi Tails LED tail lights for my 67 Chevelle - advice? - Chevelle Tech
post #1 of 6 (permalink) Old Feb 3rd, 19, 10:32 PM Thread Starter
Ken
I'm considering having these Digi Tails LED tail lights installed in my 67 Chevelle. Does anyone have these in your car?
https://youtu.be/apO5gwztI94
darksky is offline
post #2 of 6 (permalink) Old Feb 3rd, 19, 10:39 PM
B
Re: Considering Digi Tails LED tail lights for my 67 Chevelle - advice
I don't have them but I like them. Extreme Performance Products makes some for the 71-73 taillights and I like them. I say go for it.
'71 Malibu coupe
BWolfe84 is offline
post #3 of 6 (permalink) Old Feb 4th, 19, 12:42 PM
Rob
i am unhappy with the output on my 69 for what its worth.
digi tails i bought from opgi catalog
daytime the brakes are just not bright enough
maybe its the design, the way the board is mounted is not close enough to the lens
ROB
69 El Camino
robpp is offline
post #4 of 6 (permalink) Old Feb 4th, 19, 3:54 PM
LED lighting is a funny set up. To get the most out of your lights they should be SQUARE to the rear, If they are at an angle you do not get the full effect of LED.
I installed LED ( Stop & Tail ) in my 70 Wagon, At first they SUCKED, WHY?
They were sitting at an ANGLE so I shimmed them up so they are SQUARE to the rear, NOW they are VERY VERY BRIGHT and just PERFECT.
For a test........ The LED lighting from the factory or any big truck. When you are in the direct line with the light it is fine, Walk a bit to the left or right and then You may see the difference. My LEDs in my wagon are fine, And the are not bulbs they are Square boards with a gang of ( HI & LOW ) LEDs.
Do some research on different types of LEDs and then REACH for your wallet!
Robinls5 is offline
post #5 of 6 (permalink) Old Feb 4th, 19, 4:55 PM
bob
I agree with others, don't waste your money on LED. I changed mine back to reg. bulbs.
bobm67 is offline
post #6 of 6 (permalink) Old Feb 4th, 19, 5:24 PM
I used these ([ame="https://www.amazon.com/gp/product/B01D8BT40O"[/ame]) and of course a new flasher ([ame="https://www.amazon.com/gp/product/B06XS8VX2W"[/ame]) and am quite happy with the results. These bulbs fit just like incandescent so they are really easy to swap in. Here's the result:
https://youtu.be/QLrFynsAAqY
Brad Waller
'66 Corvette | 352/??? | 4-speed | Wilwood Brakes | 245/50/16
'67 Chevelle | ex-SS396 | 355/700R4 | F-Body Brakes | 275/40/17
Brad Waller is offline
LED tail lights for 71 growup51 Chevelle Tech 2 Feb 3rd, 15 12:20 PM
custom tail lights?? chevyshack Body Shop 18 Feb 1st, 13 11:07 AM
1970 Chevelle tail lights: flat vs. bubble GotGrunt What's it worth? 9 Dec 19th, 12 8:40 PM
Spaghetti Engineering Digitails LED 66 Chevelle 73z-6sp Electrical & Wiring 1 Dec 14th, 12 10:35 PM
Good or bad price for Sheet Metal Items joeperl Body Shop 4 Oct 26th, 12 2:52 PM
