Radio Noise Capacitor - Chevelle Tech
 2Likes
  • 1 Post By Billdini
  • 1 Post By Dean
post #1 of 7 (permalink) Old Feb 1st, 19, 11:16 AM Thread Starter
Lou
Hi,
would anyone happen to know if Radio Noise Capacitors go bad. I've got an original that was bracketed to my coil. It still looks good on the outside but am not sure what's going on the inside and what if anything goes bad inside. It's that silver cylinder about 5/8" in diameter and about an inch and half long with one wire coming out.
Lou
1943MB is offline
post #2 of 7 (permalink) Old Feb 1st, 19, 11:37 AM
Re: Radio Noise Capacitor
You can check it with an ohmmeter
post #3 of 7 (permalink) Old Feb 1st, 19, 11:51 AM
Originally Posted by 1943MB View Post
Hi,
Lou
All components can go bad. If it shorted it would kill the engine and if it is open you will just have more radio ignition noise coming out of the speakers. Easy to check with a meter, especially an older analog meter or a modern DVM. Just connect the leads between the wire to positive lead and the black lead to the case and you will see the resistance change as the capacitor charges which is how it should be. It will go from a short to open while it charges if your meter has the ability. I am not running one on my Chevelle but I am also no longer running points and I have been told its not needed by wiring/electronics specialist with electronic ignition. However it will not hurt leaving it on if its not shorted.
Billdini is offline
post #4 of 7 (permalink) Old Feb 1st, 19, 12:14 PM Thread Starter
Lou
Hi thanks for the info. I've got one black wire from the capacitor. Is that a red connect or a black connect from the meter. Where does the other wire go ? What setting is the meter set to. What am I looking for on the meter. Meters need batteries which go bad. I don't much care for meters for what that's worth. Can I check it with a 12 volt light probe and a 12 volt battery ?
1943MB is offline
post #5 of 7 (permalink) Old Feb 1st, 19, 12:48 PM
I don't believe those caps are polarized meaning they are not polarity sensitive but to be safe connect your red OHM meter lead to the wire coming out of the cap and the black wire to the cap case. Use a lower OHM setting. Remember you are testing resistance and not voltage. Also make sure the wire is disconnected from the coil or it could back feed through the points. Nope test light will not help. You might also want to test the cap case to engine ground to make sure all your ground connections are good. As far as meters needing batteries that is a must since resistance applies a battery voltage to the component being tested. Ground the wire coming out of the capacitor for a couple seconds to make sure it isn't holding a charge before you check for resistance.
1943MB likes this.
Billdini is offline
post #6 of 7 (permalink) Old Feb 1st, 19, 1:32 PM
You put one lead on the case and the other on the wire lead and then reverse the meter leads.
That charges and discharges the capacitor and the meter will go up, then back down as it charges then discharges.
You can do it over and over.
If the meter does nothing OR stays up, the capacitor is bad.
A larger capacitor (which it's case is not connected) but the theory is the same.
1943MB likes this.
post #7 of 7 (permalink) Old Feb 2nd, 19, 10:42 AM Thread Starter
Lou
That charges and discharges the capacitor and the meter will go up, then back down as it charges the discharges.
Start Run Capacitor Testing Using A Cheap Meter DIY (HVAC/Stereo/Microwave/Electronics) Service - YouTube
Okay, got it. Thanks
1943MB is offline
'70 Radio noise surpressors? Robinls5 Electrical & Wiring 8 Sep 19th, 18 12:12 AM
The BEST direct fit RADIO for Classic / Muscle Cars! MCB Sponsors 51 Jan 2nd, 18 2:31 PM
Radio Noise with HEI warner52 Electrical & Wiring 3 Apr 19th, 17 10:04 PM
How to eliminate the factory radio and have music... WILD72 Electrical & Wiring 17 Nov 10th, 13 10:02 PM
Voltage Regulator Radio Capacitor for 1970 Chevelle Mark2Mac Restoration Corner 3 Apr 23rd, 13 9:46 PM
