Blower motor help - Chevelle Tech
  • 1 Post By goodnight144
post #1 of 11 (permalink) Old Jan 27th, 19, 12:11 PM Thread Starter
Cody
Blower motor help
I recently did a conversion to an ss dash on my 70 chevelle and used the harness and gauges from a monte carlo. I'm not getting any power to my heater blower motor now. Ive confirmed that the fuse is good and that it is getting power. The motor runs if I jump it off the battery. If I hook up power from the battery to the tan wire it will run on high. Im wondering if it is hooked up differently on the monte carlo than the chevelle. I couldn't find anywhere to hook up the harness in the picture but the brown wire on it has power. The wire pictured is where I believe the power fed in before doesnt get power when I hook it up to the only wire that fits into it (which is a different color than the previous harness wire).
ID:	584652   Click image for larger version
ID:	584654   Click image for larger version
ID:	584656   Click image for larger version
goodnight144 is offline
post #2 of 11 (permalink) Old Jan 27th, 19, 2:34 PM
Al
Re: Blower motor help
Was your car originally equipped with a/c? I'll get you a bump to the top of the thread list see if we can get a quick answer. I'll have to dig in to give you a 100% answer and it will take me some time because I'm busy with the honey do's.
Maybe this wiring diagram will get you started.
Name:	1970 CHEVELLE WIRING DIAGRAM ss ccw  best copy.jpg
post #3 of 11 (permalink) Old Jan 27th, 19, 2:48 PM Thread Starter
Cody
The chevelle was originally an ac car. Unfortunately I don't know if the monte carlo that the harness came from was.
post #4 of 11 (permalink) Old Jan 27th, 19, 3:04 PM
Al
So you probably don't know the year of the monte harness either? OK....we'll get this done. There were some changes made depending on the years. If this is your only issue you've lucked out. There are big differences in the idiot light vs gauge package wiring systems for 70.
OK. Check the wiring diagram I inserted into a previous post. Click on the attachment, then click on what pops up and it will expand for a better view. If you have an AIM, wiring diagrams for the various versions are listed there.
If you kept your stock wiring harness, you maybe able to reverse engineer the connection if they differ.
Maybe someone will pop in and help me out here...I'm rusty here and need to brush up, but still involved with the honey dos.
Does that wire in your hands fit on the blower motor switch on the dash? If there is one there, it may still be from the original harness. Don't start chopping and hacking, we may have to use some of your old wiring harness to get this done.
post #5 of 11 (permalink) Old Jan 27th, 19, 3:56 PM Thread Starter
Cody
I'm about 75% certain it came out of a 70 monte carlo as the radio that was with it was correct for a 70. The wire in my hands does not fit onto the blower motor switch. I have a set of heater controls that I randomly acquired somewhere that it does fit perfectly on the control switch for but I don't know what it came from (I'm fairly certain some kind of gm a body car). From what I can tell from the old harness the brown wire that is hot on the connector was what powered the system on the old harness but connected differently.
The only other problem I've run into so far as I can't get the turn signal indicators to light up despite replacing the bulbs but I'm not too worried about that as the turn signals are working.
post #6 of 11 (permalink) Old Jan 27th, 19, 4:54 PM
Al
Is there power to the brown wire with the crimp on connector? If there is no power there, this may be your issue. I think you said there was power to the other brown wire with the factory connector that is currently not connected to anything. The brown wire supplies power to the blower switch from the fuse box....if I'm reading this correctly.
We can work on your turn indicator lts when we resolve the heater issue. It may be related to a ground connection, which I don't think would affect the blower motor controls.
post #7 of 11 (permalink) Old Jan 28th, 19, 8:28 PM Thread Starter
Cody
So I used a jumper wire and connected the brown wire on the harness to the connector that provides the system with power. Now it will come on but only on the high setting. I have determined that the blower resistor in the engine bay is completely missing so would that explain why I don't have the other speeds?
post #8 of 11 (permalink) Old Feb 1st, 19, 7:27 PM
Yes, it would.
'71 chevelle, 468, TH400, 12 bolt posi w/3.08's, drinks a lot of 87 octane.
v8440 is offline
post #9 of 11 (permalink) Old Feb 1st, 19, 7:37 PM
These cars had a separate "add-on" harness when A/C was to be installed. The A/C harness you took from the Monte should have a rubber grommet to go through the fire wall and an inline fuse holder that goes on the firewall.
Here''s the A/C wiring:
LS1tech.com supermoderator.
How may I help you?
1999 Trans Am-500hp
paul bell is offline
post #10 of 11 (permalink) Old Feb 1st, 19, 7:40 PM
https://www.ebay.com/itm/AIR-CONDITI...2GMr:rk:1:pf:0
How may I help you?
1999 Trans Am-500hp
post #11 of 11 (permalink) Old Feb 1st, 19, 7:47 PM
DUTCH MAX HEADWORK, the PDF file you linked, do you have one for 1971? I've never seen it that detailed and clear.
How may I help you?
1999 Trans Am-500hp
This Thread is more than 386 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
