restoring dash - Chevelle Tech
post #1 of 4 (permalink) Old Jan 24th, 19, 10:36 PM Thread Starter
restoring dash
am putting tach and clock in my ss el camino but when i took plastic gauge part out of dash i noticed there are 4 paper like pieces that are covering holes about an inch in diameter on plastic lens(3 little green dots on each piece) well im missing one of those and i dont know if theyre needed and where do i get one? ty
tom c is offline
post #2 of 4 (permalink) Old Jan 24th, 19, 11:21 PM
Re: restoring dash
The year of your vehicle would be helpful.
***edit*** -- I see in another of your questions it's a '70.
David
davewho1 is offline
post #3 of 4 (permalink) Old Jan 25th, 19, 11:13 AM
Re: restoring dash
Sounds like the original light shield gaskets. To block extraneous light and to fill the small gaps, a ring with polyester foam was used between the cardboard light shields and the dash part assembly. These deteriorated over the years, just leaving a paper ring, if that.
You may have to improvise something.
Coppertop is offline
post #4 of 4 (permalink) Old Jan 27th, 19, 10:09 PM Thread Starter
Re: restoring dash
ty thats what i thought ty again
tom c is offline
This Thread is more than 433 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
