67 Dash Clock - Chevelle Tech
  • 1 Post By Pioneer4x4
post #1 of 10 (permalink) Old Jan 24th, 19, 12:00 PM Thread Starter
67 Dash Clock
After reading a thread I thought about trying to get my old dash clock to work on my 67 that I removed and put a blank plate in. I took the clock apart last night and cleaned the points and winded it up and put it together to test. There is power and at the contacts it sparks and opens and then it winds down and when the contacts touch they spark and open again. The clock doesn't tick and it is not frozen or have dirty gears because I can spin it easily now and hear a tick. Any suggestions? Thanks.
JROCK142 is offline
post #2 of 10 (permalink) Old Jan 24th, 19, 8:34 PM
Re: 67 Dash Clock
If it winds down and resets and repeats it should be working. I can't hear very well and if I put my ear right up to it I can just hear it. But it's not loud to me. While it's windings down you should see the little wheel spinning and gear movement. Do they move?
"... the very powerful and the very stupid have one thing in common. They don't alter their view to fit the facts, they alter the facts to fit their view." Dr. Who, 1977
NW68SSBBC is offline
post #3 of 10 (permalink) Old Jan 24th, 19, 8:54 PM Thread Starter
So when I wind it up and then put it together and the clock starts working but the second hand doesn’t move even with power. The points look very clean and there is power at the coil and points. Once the wheel moves around and contacts the points there is a spark and it bounces back a little and then goes slowly until it touches which takes about 10 seconds and then sparks and shoots back again but the clock is not ticking.
JROCK142 is offline
post #4 of 10 (permalink) Old Jan 24th, 19, 10:07 PM Thread Starter
Ok she works now but it resets about ever 40 seconds not 2 - 3 minutes.
JROCK142 is offline
post #5 of 10 (permalink) Old Jan 25th, 19, 2:51 PM
Re: 67 Dash Clock
Lubrication is the key. I use fine precision Teflon based oil.
But, years ago I spoke with a professional Horologist, anywhere from 40 seconds to 2 minutes is deemed “acceptable”.
Coppertop is offline
post #6 of 10 (permalink) Old Jan 25th, 19, 7:32 PM
Re: 67 Dash Clock
I get about 45 seconds to a reset. I agree about proper lubrication being important. Also a weak coil would also make for a took short reset set time. You would have to know the resistance it's supposed to have and I have no clue. I'm going to run mine as is
Good luck
post #7 of 10 (permalink) Old Jan 25th, 19, 10:39 PM
Randy
Re: 67 Dash Clock
You been looking for a reason to use that word on us!
Randy
TC # 5401
67 Project SS Clone
pnugene is offline
post #8 of 10 (permalink) Old Jan 26th, 19, 9:47 AM
Re: 67 Dash Clock
Good luck
Just curious, are you testing with engine running? There is about 2 more volts when running, so it would wind a good bit more and run longer per wind.
fishhead likes this.
Pioneer4x4 is offline
post #9 of 10 (permalink) Old Jan 26th, 19, 10:43 PM
Re: 67 Dash Clock
No. I'm bench testing it with a battery jumper pack and my wife used it to pump up a tire (it has a little tire inflator on it) so it's probably not fully charged
Thanks Joe
post #10 of 10 (permalink) Old Jan 27th, 19, 9:26 PM
Shane
Re: 67 Dash Clockvg
v vb vb
fishhead is offline
This Thread is more than 437 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
