headlight switch - Chevelle Tech
post #1 of 2 (permalink) Old Jan 20th, 19, 10:34 AM Thread Starter
headlight switch
I want to replace the headlight switch in my 1964 Malibu. I know how to push the button on the old switch and remove the knob. Behind the knob there's what looks like a metal washer, about the size of a penny, with two small holes in it, opposite each other. How do I remove this? And then, how do I remove the switch itself?
jimaustin is offline
post #2 of 2 (permalink) Old Jan 20th, 19, 10:38 AM
Re: headlight switch
The 2 holes are for what is called a pin spanner. That is the tool that will help you rotate the washer-looking part and unscrew it from the switch. You can use the tips of needle nose pliers or snap ring pliers to rotate the part.
JWagner is offline
