Reverse switch wiring routing - Chevelle Tech
post #1 of 9 (permalink) Old Jan 19th, 19, 10:49 AM Thread Starter
I am having trouble figuring out where exactly the reverse switch wiring from Muncie enters the firewall from the transmission. Anyone have a pic?
Bad67SS is offline
post #2 of 9 (permalink) Old Jan 19th, 19, 11:53 AM
blm
Re: Reverse switch wiring routing
When I first got my car it had an M21 with no reverse lights hooked up. So I acquired a Hurst reverse light switch that mounts on the rear of the shifter. Then simply drilled a small hole in the shifter hump to bring the two wires up through then ran them under the carpet to the base of the steering column.
I know that is not correct as they originally had a backdrive unit that made the reverse lights work. There were no wires involved from the shifter.
blm is online now
post #3 of 9 (permalink) Old Jan 19th, 19, 12:33 PM Thread Starter
Great idea, but I prefer to run the stock configuration. Assembly manual isn't really clear. Hopefully someone can chime in with the precise factory location.
Bad67SS is offline
post #4 of 9 (permalink) Old Jan 19th, 19, 12:40 PM
blm
What I am tring to say is there is no stock configuration because wires were not used. The reverse lights were actuated with a mechanical backdrive unit.
blm is online now
post #5 of 9 (permalink) Old Jan 19th, 19, 1:08 PM
On a 67 there is not a backdrive unit. I believe a 67 has the switch mounted on the transmission. This switch plugs into a connector that goes through the firewall in the steering column area. If I remember correctly this hole was fairly large, 1/2 +or -. There are two green wires coming from the interior that had a round soft rubber connector, plug molded to the end the went through the firewall. Hopefully someone will post some pics to show the exact location.
25C 70 is online now
post #6 of 9 (permalink) Old Jan 19th, 19, 1:27 PM
blm
My bad. Was referring to my 69.
blm is online now
post #7 of 9 (permalink) Old Jan 19th, 19, 1:48 PM Thread Starter
Exactly. I need a pic of the wires and grommet in the firewall...
Bad67SS is offline
post #8 of 9 (permalink) Old Jan 19th, 19, 2:07 PM
https://www.chevelles.com/forums/35-...dimple-id.html Look at #5 post Looks like location may vary a little depending on where car was built.
post #9 of 9 (permalink) Old Jan 19th, 19, 2:53 PM Thread Starter
That's it! Thanks!
Bad67SS is offline
This Thread is more than 396 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
